Confused :(
Old Jul 23, 2009 | 11:04 AM
9412Valve's Avatar
Default Confused :(
So, last Sunday I jumped into the install of my airdog 150 - and.. I haven't been able to drive the truck since then. The hobby shop I work out of hasn't been open until this afternoon - when I'm going to finish the install. A big hold up for me was finding exactly what connects to the "T" fitting by the injection pump - I already installed the injector return line and the T fitting with the banjo bolt.. but where does the rubber line go? And where does the other end of the "T" fitting connect to? After looking at the directions and pictures hundreds of times, I can't for the life of me figure out what it's connected to. Any help is appreciated
Old Jul 23, 2009 | 04:47 PM
94 12valve's Avatar
one end of the t is connected to the fuel return on the pump, the injector return screws in the top and the other end of the t connects to the stock fuel return line that runs to the tank.
Old Jul 23, 2009 | 09:26 PM
12valvetater's Avatar
he said it youll see that the return off the pump is a steel line for a little while and the theres a rubbe hose pull that hose off put the hose on the gave to and connect it to the t fitting the return line off the pump is the one all the way at the front on the on the engine side
Old Jul 24, 2009 | 06:17 PM
9412Valve's Avatar
Sweet thanks! Got it working!
brodey
Mar 29, 2015 12:12 PM
