oil in plug for 4k kit install
Old Jul 23, 2009 | 10:19 AM
dan33klein's Avatar
Default oil in plug for 4k kit install
hey guys it was to wet this morning to go to work right away so i started ripping into my truck.
i removed the solenoid and removed the 7/8 plug. i also measured the nut with a calipber and got .052. is that ok? anyway oil is filled all the way up to the plug and i didnt know if removing any of it would make anything easier or if anyone had any tips i would appreciate it.
thanks
Old Jul 23, 2009 | 10:57 AM
9412Valve's Avatar
The oil level was filled up to my plug as well, I lost a little bit, but it didn't effect my install of the gsk. Make sure you have a pencil magnet.. makes things ALOT easier. .
Old Jul 23, 2009 | 11:44 AM
biged681985's Avatar
oil is normal inside there. i sucked it out of mine just to make it a lil easier to see inside there. pencil magnet and a small pick work good for the washers. good luck with the install.
Old Jul 24, 2009 | 01:00 AM
94cummins12v's Avatar
there better be oil in there, its a oil lubricated fuel pump, without the oil your fuel pump, no more pumps
Old Jul 24, 2009 | 02:03 AM
12valvetater's Avatar
i did mine off the truck so it made it easier but i didnt thave any washers under the small springs
Crabber0001
6.0L Performance
Aug 4, 2015 12:30 PM
Apr 29, 2015 08:20 AM
Gman30
Dec 27, 2014 12:46 PM
Cummins_Power_13
Dec 22, 2014 05:45 PM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
