Kickdown
Old Jul 21, 2009 | 06:27 PM
DirtyDozen's Avatar
Default Kickdown
any ideas on how to deal with the kickdown issues that come with turning the pump up on automatic trucks? with the push-cable setup on these rigs the only thing i can think to do about it is to make a longer lever for the trans end of things to deal with the longer throw up top? is there a better way to go about this?
Old Jul 21, 2009 | 06:52 PM
RSWORDS's Avatar
what longer throw? Your talking about the tranny I assume. What exactly are you doing to the pump to get the longer throw? The kick down cable for the tranny has a good bit of adjustment in it.
Here is a write up on adjusting the kickdown
http://dens-site.net/Dodge_CTD/Kickdown_Adjustment/
Old Jul 21, 2009 | 07:17 PM
DirtyDozen's Avatar
the longer throw i was referring to was the change in distance between low idle and full fuel on the throttle cam, i turned the fuel screw up two turns and had to idle it down to compensate for the difference, bringing the cam forward left me about a 1/2 inch gap between the pin and the back of the slot on the kickdown cable, i diddnt know that these cables were adjustable.
Thanks for the info, that link was exactly what i was after
Old Jul 21, 2009 | 07:21 PM
sidekick's Avatar
good deal that you figured it out
