Fuel Plate
Old Jul 20, 2009 | 02:40 PM
12valvetater's Avatar
Default Fuel Plate
i got my truck running again it has stock injectors now since my 370s were junk and i put a #4 plate in. it seemed like it was running really hot like cruising at 60mph with 10 pounds it was running about 800-900* with heavy smoke so then i put my stock plate in now it doesnt smoke at all feels like it has no power and runs about 700* and the throttle feels like its really hard to push past 1/4 throttle and it wont get over 900* is there something wrong that would make it feel like it has no extra power past 1/4 throttle?
Old Jul 20, 2009 | 11:41 PM
12valve4life's Avatar
The only thing to help your power problem is try a new plate. I suggest a #100 or #0. Those 370's have the wrong spray pattern, therefore they make the truck run hotter. I wouldn't suggest them to anybody.
Old Jul 21, 2009 | 11:00 AM
bowtech's Avatar
he has the stock injectors in not the 370s. wats your air intake setup?
Old Jul 21, 2009 | 12:08 PM
Yea, but im just saying on a side note, that they will make it run hot.
Old Jul 21, 2009 | 12:46 PM
BAD ASS RAM's Avatar
check your plate,that happened to me once.when i put it together somehow i got ig crooked.the foot in the afc was binding on the plate so it was having a hard time moving,i don't think it was moving at all.i always now put the afc on with the plate loose to make sure it's sitting good,then take it off and tighten the plate.are you getting much boost?
Old Jul 21, 2009 | 01:06 PM
well now he thing wont start at all the fuel shut off selinoid wont open up
Old Jul 21, 2009 | 01:12 PM
bowtech's Avatar
that happend to me the arm on the shut off came off or u might of bent it make sure it is on the pin and not bent.
Old Jul 21, 2009 | 01:18 PM
it works if i hold up on it when somebody cranks the engine over
Old Jul 23, 2009 | 12:02 AM
Theres a relay attached to the firewall, leading to the fuel solenoid, pull it apart and put some dialectic grease in it. make sure to blow it out first.
Old Jul 23, 2009 | 09:23 PM
i dont think mine has any relays on the firewall i was checking the service manual the other day and i cant find the 2 relays that are up on the firewall
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
crayons
Mar 20, 2015 03:50 PM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Nov 15, 2014 07:35 PM
