Timing Advance
Old Jul 20, 2009 | 09:15 AM
dixierebel0213's Avatar
Default Timing Advance
just wondering what kind of things i should look for with a timing advance? more bottom end, less bottom end more top end,less top end, higher egts, quicker spool basically the good, the bad and the be weary of. trucks a 93 single wheel in the process of a tranny build with better torque convertor, turned up pump, bhaf, stacks, and shopping for a turbo better suited for towing oh and about how many degrees is a good number
Old Jul 20, 2009 | 05:41 PM
stillcummin's Avatar
adavancing timing will yeild better "top" end.It does raise temps though ,as well as cylinder pressure.to much and youll blow a HG.I wouldnt go above 1200f. If thats what your talking about.
Old Jul 20, 2009 | 07:03 PM
RSWORDS's Avatar
your pyro should read lower because you are burning all the fuel more efficently. You will see a good jump in fuel milage and better throtte responce. 1/16" to 1/8" bump should not yeild and bad traits unless there is already a problem. I would not tow heavy with any more then a 1/8" bump.
Old Jul 21, 2009 | 10:54 AM
when you advance it would be rotated to the motor(top) or away?
Old Jul 21, 2009 | 04:13 PM
RSWORDS's Avatar
yes the top goes towads the engine. If you look were the pump meets the timing case there should be a mark on it (if not make one with a chisle) use that mark to mearsure your distance.
Old Jul 22, 2009 | 08:13 AM
sweeeet man i freakin love this truck. other than the tranny i feel like ive gained twice the horsepower and torque for like 30 bucks cant do that with a newer cummins
quiksilver1j
Jul 30, 2015 12:41 PM
Stox5225
22
May 14, 2015 05:17 PM
Derag2
Apr 2, 2015 07:57 PM
SMatyac
Nov 15, 2014 07:35 PM
91 7three
Nov 14, 2014 10:37 PM
