Fuel Pressure Readings
what is everyone getting for fuel pressure readings? I was getting around 10 when cruising and 5-8 psi under hard excelleration. I sent my adrenaline back (as did all beta testers) in to get the component added to my module and two or three nights after I installed it I was in bumper to bumper (which I am never in) and I started seeing over 20 psi while idleing. But when I started traveling again i was fine and withon my normal limits) and seems like after that I have been getting wacky readings. yesterday I was pulling some trees out of the brush and while it was idling I saw 48 PSi. This morning when I started it up first thing I saw 44psi. then while cruising it never got below 18psi.
is there a sensor issue or maybe a connection issue or a pump issue.
i would put a gauge on it before i would use the quad for pressure monitoring. Autometer, Isspro, Diprocal (sp) or even glow shift.... they have proven they work, and work reliably, time and time again....
just an update.
The issue was intermittent. so I figured it had to be a wiring problem. So I checked the connection and was able to get the reading to move. I added dielectric grease to the plug and problem solved. I get about 8 at idle
