Injection pump replacement instructions
Old Jul 19, 2009 | 07:53 PM
jjacobi49's Avatar
Default Injection pump replacement instructions
I'm getting ready to replace my injection pump. Anybody have a good place to get remove and replace instructions or know of a good manual? Having trouble finding them.
Old Jul 20, 2009 | 11:29 PM
wildbill's Avatar
Hello Danno!!!
Old Jul 21, 2009 | 05:35 PM
2500HeavyDuty's Avatar
heres a link to my photo album when i relaced the cp3.
cp3 replacement pictures by 2500heavyduty - Photobucket
you will need an assortment of deep and regular metric sockets, 19mm crows foot. and a 27mm socket iirc for the cp3 gear and puller.
you will have to remove power steering bracket, altinator bracket, thermostat housing, coolant crossover tube, and all fuel lines in around the cp3. the greenish steel return lines can be unbolted and bent out the way for removal of the cp3.
there is 4 bolts holding the cp3 to the front of the engine, you removing it you will have to slowly wedge it out with screw drivers and pick it up and roll it out from the bottom towards you.
this details are in short i can explain better if you have q's
Old Jul 21, 2009 | 07:19 PM
jjacobi49's Avatar
Thanks for the photos! Removed the old one today in about 3 1/2 hrs. Going back together tomorrow. Your pictures are a big help!
Old Jul 21, 2009 | 07:22 PM
nice work that was pretty quick
Old Jul 22, 2009 | 10:22 PM
jjacobi49's Avatar
Put it back together today. Took 3 hrs. No extra bolts and its started right up!! Going to test drive tomorrow. Not a hard job, just have to remember where everything goes. Pics really helped.
Whats the best way to bleed the coolant system? I filled it up but want to make sure there isn't any air trapped. Thanks
Old Jul 23, 2009 | 05:02 PM
there is a bleed screw on the top center of the thermostat housing
Old Jul 24, 2009 | 01:20 AM
RodZZilla's Avatar
WhiskeyRiver took my mind
Nice write up Dan.
Old Apr 19, 2010 | 03:20 PM
sjsperdute's Avatar
i m new to the site and i know this is an old post, but is there a way i can see the picture for cp3 replacement. i can't open the link, and i am planing on doing this this weekend. thanks
Old Apr 20, 2010 | 01:59 AM
the password is daniel
