Diesel Related Events Post All Diesel Related Event Information, Dates and Results Here - Includes Racing, Pulling, Dyno ect... All Local, State and National Event Information
*POST AND DISCUSS ALL DIESEL RELATED EVENTS HERE*
Edgar Co. (Paris) Illinois Truck/Tractor Pull
Old Jul 19, 2009 | 06:09 PM
1155puller's Avatar
Default Edgar Co. (Paris) Illinois Truck/Tractor Pull
Thursday July 23, 2009
Truck and Tractor Pull
7500# 4X4 and 2X4 trucks
1. Edgar Co. Residents Only
2. Truck must be street legal (license, registration, etc…)
3. 30 inch maximum hitch height
4. No front weights
5. No solid suspension
6. No open headers
7. Stock Pump and Turbo on Diesels ( No Excessive Smoke!)
8. No power chips
9. No traction bars
10. Must have driveshaft loop of some sort (chain, strap, etc…)
#8500 Diesel Pickups
1. 26" maximum hitch height
2. Safety chain or loop around rear driveshaft
3. No nitrous oxide or propane injection
4. Must run DOT approved tires, Duallies allowed
5. No side exit exhaust in front of rear wheels
6. Superintendents decision final and takes precedence over printed material
5800# Indiana ModifiedTractor Pullers Association
10,000# Illinois Stock Pullers N/A “Smokers”
12,000# Illinois Stock Pullers N/A “Smokers”
9500# Illinois Stock Pullers Limited Pro. Stock Tractors
20,000# Stock Farm Tractors
1. No cut tires
2. No power chips
3. Stock fuel Pump and Turbo
4. Stock RPMs
5. 20 inch maximum drawbar height
6. Stock drawbar
7. Weights must be secured
8. Cannot use MFWD (if equipped)
9. No speed limit
Start Time: 6:30 p.m.
$10 Pit Gate Fee (One driver will be allowed entry with pulling vehicle)
$20 Entry fee for all non sanctioned classes
Friday July, 24 2009
6500# 4x4 and 2x4 Trucks
7500# 4x4 and 2x4 Trucks
1. 26” hitch height 4x4 trucks, 30” 2x4 trucks
2. DOT approved tires with 35” tall maximum. No Cut Tires.
3. Pull from bumper or reese hitch rigid to the frame, must originate from behind rear axle, hooking point must be no less than 42” from the center of the rear axle with no supports attached to the rear axle.
4. May run front weights. No weights, brackets, or bumper to extend more than 60” from center of front axle.
5. Safety chains or loops around driveshafts.
6. Pump fuel only; no alcohol, nitrous oxide, or methane based fuels allowed, no water injection
7. Headers allowed, Open headers allowed, no side exit exhaust in front of the rear wheels.
8. Superintendants decision final and takes precedence over printed material.
12,000# Farm Stock Tractors
14,000# Farm Stock Tractors
1. No cut tires
2. Stock appearing fuel pump and turbo
3. Stock RPMs
4. 20 inch maximum hitch height
5. Weights must be secured
6. 9mph speed limit
STOCK APPEARING FARM TRACTORS (subject to inspection before and after pull by officials)
7. Superintendants decision final and takes precedence over printed material.
14,000# Open Speed Farm Stock Tractors
Same rules as 9mph tractor class except for rule #6 (Any speed is permitted)
7,000# Illinois Hot Farm Stock Pullers Association Tractors
9,000# Illinois Hot Farm Stock Pullers Association Tractors
Edgar Co. Fairgrounds is located in the North end of Paris, IL on Illinois Rt.1
Questions call: Bruce Barrett (217)822-8371
Nathan Barrett (217)822-8370
Old Jul 25, 2009 | 03:11 PM
oglejust's Avatar
that was the best truck pull weve had so far, except the track was really loose.
