95 prospector 1/2 ton 4bt front axel
Old Jul 19, 2009 | 05:48 PM
stillcummin's Avatar
Default 95 prospector 1/2 ton 4bt front axel
Im putting a matching gear set in the front dana 44, to match the rear 3.55.Ive got my pinion depth set right,but im worried about the backlash of .015".Manual says spec is .004"-.009".I was wondering if anyone thinks this will be to loud when engaging?
Old Jul 20, 2009 | 01:24 AM
tower_ofpower's Avatar
the spec is .004-.009 with a .006 tolerance + or - your backlash at the deepest mesh. according to factory your just fine, but there will be a slight noise, nothing anyone or yourself will cringe over.
Old Jul 20, 2009 | 05:00 AM
LOGANSTANFORTH's Avatar
yeah its going to make a little loud until it wears in, its always good to set new parts up just a hair tight cause wear will loosen them up.....
Old Jul 20, 2009 | 05:04 AM
where does this info come form?My factory manual doesnt say that.
Old Jul 20, 2009 | 06:49 AM
not the owners manual, a factory service manual or possibly a haines...
Old Jul 20, 2009 | 05:38 PM
I have 2 different "factory" chrysler service manuals,and thats not in there!please dont tell me your making this up.who said service manual anyways?
Old Jul 20, 2009 | 09:08 PM
not making it up, i recently graduated from the univeristy of northwestern ohio. at the college we had axcess to "all data" and "mitchel on demand". when i was running around with my gasser i blew apart the chrysler 9 1/4 and rebuild it with a set of richmond gears and a LSD. the online manuals said that there is a .006 tolerance from the spec. i can't remember where i had mine set at but it was more torwards .007 backlash and the rear was quite as could be, no harsh engagement or thud.
At any rate maybe that "newbie" status will disappear... makes my credibility kinda iffy... yes, i'm young and fresh out of college but if i'm listening i soak it all up.
Old Jul 21, 2009 | 10:09 AM
glad too see another graduate here, August 07 here, im glad you got to set them up cause i brought in my buddies 1997 1/2 ton and they didnt have the tools to do the newer rearends, just the older style......
Old Jul 21, 2009 | 04:12 PM
RSWORDS's Avatar
post count means nothing around here... look at how many I have and I dont know my *** from a hole in teh ground
Old Jul 21, 2009 | 07:17 PM
well rs, if you dont know your *** from a hole in the ground, and people fall into holes... does that mean people fall into your *** often? and logan your alum from UNOH? heh... small world
