hx35/40 waste gate
Old Jul 19, 2009 | 09:31 AM
dan33klein's Avatar
Default hx35/40 waste gate
hi guys how do i know what position the arm on the turbo should be at for the waste gate to be closed?i would imagine when the arm on the acuator is in the waste gate is closed. and when you put air in the acuator or moved the rod out manual the waste gate opens.
is this correct?
Old Jul 20, 2009 | 07:06 AM
BAD ASS RAM's Avatar
yes,if you are looking at the arm on the gate,if it's up it's open,if it's pointing toward the motor it's closed.
Old Jul 20, 2009 | 07:24 AM
dan33klein's Avatar
the lever on the turbo moves feely..
not to sound dumb but i dont understand your position logic.
i think mine my be stuck open
please be more clear
Old Jul 20, 2009 | 07:35 AM
if you are under the truck looking at the lever/arn on the waste gate(the one that the actuator pushes)if the arm is pointing up it is open,when it closes it comes down and points toward the motor.mine moved freely too when it was disconnected from the actuator.the actuator was messed up.i just took a wire and wrapped around the lever and wired it down or closed.
Old Jul 20, 2009 | 07:36 AM
dan33klein's Avatar
my acuator frunctions properly its just i cant even get the hose to stay on it.
Old Jul 20, 2009 | 07:54 AM
i wouldn't worry about it.take the three bolts out of the actuator and get it out of the way.then take the arm on the gate and work it back and forth several times to make sure it's going all the way closed.then close it,and tap it down with a hammer to close it tight,then run a wire around it and tie it off some where then it's done. i don't think you have to worry about the boost going too high.i get like 38psi with no gov.springs,and i'm probably fueling even harder than you with the injectors and all the afc mods.
in your signature it says non gated turbo.if that's the case then why are you worried about this?
Last edited by BAD ASS RAM; Jul 20, 2009 at 07:54 AM. Reason: Automerged Doublepost
Old Jul 20, 2009 | 05:21 PM
dan33klein's Avatar
wel i wasnt gunna use the wastegate thats why i did it.
i just got my 4k kit and 60lb valve springs today.
hi i took the accuator off and i can rotate the arm freely.
it moves toward the passager fender. and towards the motor.
i want it towards the motor to be closed right?
thanks
Last edited by dan33klein; Jul 20, 2009 at 05:21 PM. Reason: Automerged Doublepost
vin_diesel
Mar 1, 2016 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
six speed
Sep 14, 2015 09:19 PM
timmyd
Jun 8, 2015 11:35 PM
carid
Diesel Bombers Sponsors
Jan 19, 2015 08:30 AM
