HX35/40 vs. stock HX35 Turbo Lag.
Old Jul 17, 2009 | 10:05 PM
Meralain's Avatar
Default HX35/40 vs. stock HX35 Turbo Lag.
I run my truck daily as a commuter vehicle, and I know that I need a bigger turbo to handle any setting above 3x3 on my Edge Comp. What I am most concerned about is lag time and smoke..... What are some thoughts about going to a HX35/40 turbo to get the better airflow and cooler EGT's, benefits, drawbacks, et cetera. I don't read much here about producing power with the Cummins without a lot of smoke....I would like a setup that I can run at somewhere around 350 hp without smoking out an intersection if I am not overly careful on the throttle.
Just so its clear....I have an 01 24 Valve 5 speed currently running an Edge Comp variable chip, K&N air intake, FASS, everything else stock. I like the results of running the Edge on 3x3, however if I could move enough air...I like the fuel economy of the 5x4 setting on the Edge. As it is, I treat the throttle like it is a raw egg, but the lag is great enough above the 3 setting that I blow too much black smoke. Not a problem on the highway, but in town, yuck.
Another thought, would a smarty be a better choice here? But back to the original can of worms, how to get more airflow and better spool time. Any thoughts would be great!
Old Jul 18, 2009 | 01:01 AM
Fishin2Deep4U's Avatar
If you have smoke induced lag now, it'll be worse with the hybrid.
With a 5 speed and the ability to run a lower sublevel, you should be able to drive smoke free.
I can drive with NO SMOKE on any level with a tight converter, tall gears and taller than stock rubber. A bigger turbo will always spool slower. You can try a turbo with a better housing like a 57mm S300 or go up to a 62mm. But in either case, it'll spool slower than what you have now.
Dave
Old Jul 18, 2009 | 01:12 AM
Meralain's Avatar
That's kind of what I was afraid of. How about twins? There has got to be a way to run these suckers at a descent HP without blowing smoke all over the place!
What about running parallel turbos? I know it would be a real project to fab the exhaust manifolds, but I have the welding skills to do it--if it would work.
Thanks for the input Dave!
Another thought here, what setting do you recommend running the sub level of the Edge at Dave when I run the main on 5? I do get my best fuel mileage at that level.
I'm thinking its time to check for boost leaks as well....
Old Jul 18, 2009 | 08:32 AM
Rooster24v's Avatar
You should be able to hear boost leaks.. sounds like a WOOSH sounds when your at higher boost levels.. I have noticed that with a larger turbo it is a lot smokier in the lower RPMs, I did see something about running 2 HX35s, it was in a dieselpower magazine.
I put a AFE Blade runner on my truck, this did help with spool up and its a lot more areodynamic than the stock intake manifold..
Old Jul 18, 2009 | 02:21 PM
01quadcab's Avatar
a set of compounds would tow great and produce less smoke, but you will need more fuel for them. You could keep your stock turbo and add a bottom to the mix.
Old Jul 19, 2009 | 01:23 AM
A HX35/ S400 set can be run on stock fueling. Don't ask how I know.
If you were going to compounds, do the hybrid. But, I would recommend a HX40 over a K31 or GT42-02 for a towing set and a S400 for a street/ strip set.
The towing set will spool fast with less fuel.
Dave
Old Jul 19, 2009 | 08:59 AM
Meralain's Avatar
Dave, that sounds like what I am after! Also sounds very similar to what another diesel driver around here has done. Thanks!
Old Jul 19, 2009 | 02:16 PM
No problemo.
Dave
Old Jul 20, 2009 | 09:29 AM
BAD ASS RAM's Avatar
i have a hybrid and i am fueling very heavily,and there is almost no lag at all.before i put it on i smoked bad,now it's hard to get it to smoke.it also cooled me down by about 300*with a 14cm housing(which is what most 35's are i think)spool is not an issue.the huge exaust housings are where you get the lag at.or also way too much fuel down low.
huntman7
8
Aug 28, 2015 05:42 PM
n2brk
Feb 21, 2015 09:05 AM
D-350 dually
Feb 6, 2015 05:41 PM
BIG SOCHA
Oct 23, 2014 11:01 PM
GreenDieselF
Oct 20, 2014 02:05 PM
