turbo here advice!
Old Jul 17, 2009 | 04:40 PM
dan33klein's Avatar
Default turbo here advice!
ok guys my new hx35/40 hybrid got here today and i cant wait to paint and put it in.
i already have a new turbo/manifold gasket.
do i need any gaskets for the oil inlet or return line?
i used pb blaster but any other tips or ways to break the bolts loose? special tools?
should i bloack the wastegate right off the bat?
any input please!
Old Jul 18, 2009 | 11:00 AM
94cummins12v's Avatar
you shouldnt have to do anything with the oil drail line. other than maybe cut some off. i had to cut 3 inches of the drain tube and use some 3/4 blue high temp heter hose to run it to the block. the oil suply you dont need to mess with. soak the turbo bolts with pb blast for a few minuts then they shold break free. the turbo nuts are 15mm and the v-band clamps are 11mm
Old Jul 18, 2009 | 04:00 PM
dan33klein's Avatar
do you just take the nuts off the bolts and the turbo pops off?
cause the studs look like there fixed in the manifold.
like flexible tubing for high heat purposes?
Old Jul 18, 2009 | 04:02 PM
12valvetater's Avatar
you shouldnt have to do anything with the oil drain the turbo frame is the same as stock the only difference is the compressor is from an hx40
Old Jul 18, 2009 | 04:05 PM
dan33klein's Avatar
true that.
im hoping to tackle the job tommorow if im not busy..
the paints drying as we speak
and my 60lb valve springs and 4k kit will be here monday
Old Jul 19, 2009 | 08:19 PM
yes once you pop the nuts off and the two v-band clamps the turbo will fall right off. as for the oil drian the turbo that was on the truck when i bought it was a WH1C off a 1st gen then i put the hybrid on and the drain sat a good inch back
Chris Pittman
5.9L 12V Performance
Mar 21, 2015 05:00 PM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
