Valve Cover
Old Jul 16, 2009 | 10:42 PM
Bad93Cummins's Avatar
Default Valve Cover
I want to pull them off and clean them up and paint them, do I have to get a new gasket for the value cover once I put it back on?
Old Jul 16, 2009 | 11:08 PM
Begle1's Avatar
Supposedly, the gray gaskets are re-useable whereas the black ones are not.
Your mileage will probably vary on either color.
For the best value, you can get some Gladware containers that are just the right size. When you put a big fender washer over the top to spread out the clamp force, you not only have a very inexpensive solution, but a transparent one too. The best value out there!
Old Jul 16, 2009 | 11:19 PM
Haha i've never heard of doing that.
So most likely I would need new gasket's or could I use a make your own gasket deal?
Old Jul 16, 2009 | 11:37 PM
Begle1's Avatar
The valve cover gaskets are pretty thick and molded, and lip around both sides of the bottom of the valve cover. I don't think you'd manage to make your own. They do like to leak too.
The gray ones are better, and none of them are too expensive.
Old Jul 16, 2009 | 11:38 PM
so probley just go down to auto parts store and order some new gasket's?
Old Jul 17, 2009 | 12:38 AM
stkdram55's Avatar
thats what i would do it should run you like $50
Old Jul 17, 2009 | 03:58 AM
LOGANSTANFORTH's Avatar
i pulled all of my valve covers off and painted them on my 90 and i reused the gaskets and never had a problem, just clean everything before putting it back together......
Old Jul 17, 2009 | 04:01 PM
RSWORDS's Avatar
I've had the stock gaskets on my 89 off maybe a dozen times. One of them just barly started to leak this last time. I might need to just tighten it up.
Oh and begle... your not right...
Old Jul 17, 2009 | 10:09 PM
oh sweet deal, well then monday or tuesday ima pull them off and paint them.
What color yall think? Ima paint the truck a hemi orange color and might run black along bottom to do 2 tone(not sure yet), so should I do orange under the hood to?
Thanks
Old Jul 17, 2009 | 10:24 PM
greasemonkey's Avatar
why go through the trouble of machining a hole into the expensive glad containers? just spray the top end down with av-gas or other oil free solvent and squirt six piles of RTV silicone on there. flexible sealer will move with the rocker arms.
