03 common rail popping
Old Jul 16, 2009 | 06:26 AM
CUMMINSTD's Avatar
Default 03 common rail popping
i have a 2003 dodge 3500 5.9 cummins. whenever i turn my programmer up over 100 hp i have a bad popping noise and sputtering at a high rpm under full throttle. it shoots out fast sputters of black when it's goin on and it's only when im full throttle speeding up quickly. if im on the highway and run it on up t0 3000rpm and am at full throttle im fine. i have already installed a bd diesel fuel pump (stock bypass) and that didnt fix the problem. i know these stock fuel systems are supposed to support up to 600 hp. so i dont see why mine does this. i adjusted the valves last week so they are all right. i have 190,000 miles on stock injectors, could that be an issue too? im getting a chettering noise that i dont hear when driving any other cummins. i ran my truck with my compter hooked up and at full throttle i maintain between 20,300 and 21,599 psi rail pressure and i know bad injectors will make it lower
Old Jul 16, 2009 | 09:35 AM
wildbill's Avatar
Believe your taxing the CP3 pump. Need a meaner fuel pump.
Notso
Ford Powerstroke 08-10 6.4L
Dec 28, 2016 06:20 AM
yzrider250
Diesel Engine Conversions
Aug 10, 2015 11:33 AM
Rauch65613
May 15, 2015 10:00 AM
Apr 11, 2015 02:47 PM
Feb 10, 2015 03:10 AM
