Curious?
Old Jul 14, 2009 | 06:40 AM
dixieland1519's Avatar
Default Curious?
My dad has a 03 dodge 3500 6 speed. Its just stock but it seems to pull like a freight train. What could i do to my 96 2500 auto to get it to pull like that thing does. I wish it had the nv4500.... I just ordered stewart warner pyro, boost, and trans temp gauges. I plan on trying to grind my plate and adjust on the afc housing. But i dont kno how crazy i can get on the stock tranny.
Old Jul 14, 2009 | 08:30 AM
Coco2992's Avatar
#10 or #100 fuel plate would be good, i had a #6 plate in my 96 tranny went out not too long after
Old Jul 14, 2009 | 09:45 AM
Ok thanks thats what i was wondering about how much it could handle. Has anybody ever put a nv4600 6 speed in a 2nd generation truck? Would it bolt up?
Old Jul 14, 2009 | 05:27 PM
12valvetater's Avatar
yes but you need a donor tuck driveshafts pedals transfer case unless you swap input shafts on it master clylinder slave clylinder harness and i think the crossmember is different it can be done but its a pain to do for one and the way performance autos are now they will handle more than a straight stick if the auto is built right
Old Jul 15, 2009 | 01:36 AM
94cummins12v's Avatar
no such thing.
its either a nv4500 5 speed or nv5600 6 speed, and yes it can be done for roughly 6-10k
Old Jul 15, 2009 | 05:42 AM
davo79's Avatar
Where the hell do you get 6 to 10k from for the price. If you can find a totaled truck on craigslist that has all the parts you can do it all for less then 5 grand I got my donor truck for 1 k all I need now is the clutch and flywheel. That's another 1500 to 2500 depending on how good a clutch you want or you can get the luk clutch set with flywheel from autozone for 600 and bam its all done for less then 5000 so 6 to 10 k is way out of range there
Old Jul 15, 2009 | 10:18 AM
i just helped a guy do the nv5600 swap in his 96 auto. tranny was $3000, dual disk clutch $1600, tcase work $500 driveline shorten and thengthen $400, tranny adapter $400, shift kit $100, full synthetic flud $100, 2low kit $400, mounting harware $200, not everyone likes to go with used parts thats close to 7k
Old Jul 15, 2009 | 10:19 AM
Ive got an NV5600 and its definitely not worth 7k - Ill tell you that.
Old Jul 15, 2009 | 10:28 AM
that was for everything combined, i know he got the tranny from a guy down in florida
Old Jul 15, 2009 | 11:49 AM
ok thanks bc i already have the tranny we got from a totalled truck. it didnt cost me anything but alil bit of fuel. i kno the autos are getting beefy now but for some reason ii just feel better with a manual tranny? but i didnt want to sink no 10k in it
unless it made my truck do alil dance
Last edited by dixieland1519; Jul 15, 2009 at 11:49 AM. Reason: Automerged Doublepost
