Leaks
Old Jul 13, 2009 | 10:14 AM
Captn_tyler's Avatar
Default Leaks
This truck is worse that a boat. I just changed the t-case rear output seal not to long ago and its leaking again
I have to change my clutch, and me thinks I spotted a trans leak up there, what is the most common leak there?
Also can some give the basic steps in getting the NV5600 out from under the truck? And the things to look for that can screw me?
Old Jul 13, 2009 | 06:56 PM
turbo20psi's Avatar
You sometimes have to change the york on the drive shaft as well. I change both no problems.I dont know to much about the NV5600 I hope someone chimes in, sorry.
Old Jul 13, 2009 | 08:16 PM
bryson's Avatar
Good point. The seal can wear a groove in the yoke, so check for that. If there is a groove, sometimes you can find a different (taller/shorter/double lip) seal that seals on a different part of the yoke. If you can't find a different seal, then replacing the yoke is the way to go.
Old Jul 14, 2009 | 09:54 AM
Thanks guys, I will look at the yoke today and see if its got a grove from the old seal. Got the trans out from under the truck last night, that this is a beast.
Dbleo351
Nov 20, 2016 09:34 AM
cdhearn
Chevy/GMC Duramax 01-04 LB7
Jun 17, 2015 11:15 AM
Gm3500
May 7, 2015 11:01 AM
RatsMC
May 4, 2015 05:25 PM
ktfroy
Mar 11, 2015 11:13 AM
