leaky injector
replaced my injectors around april i think and the 4th one is wet around the base of it. (4th from the front) is the bottom nut just need tightend? cant get a cresent wrench on it. do i have to take of the fuel line?
Are you sure its the hold down nut and not the return line? Did you clean out the holes before putting them in? Most of the time you need to pull the lines to get to the hold down nuts.
i started to take my afc house off and the flat head bolt in the top right was to tight to get off so i started to take off the return line then i dont have the next size up wrench that i need.
sucks not havin the right tools for the job
i got the 10 mm dont have a wrech for the bolt down for the injector. it has been off i took it off a few time to put in the plate and mess with it. not yet brandon i was lookin at it and the piece that the pyro screws on with the threads on the out side is welded on the down pipe. can i get another or is that a special part?
