how do i gut the afc housing?
Old Jul 12, 2009 | 06:36 PM
bowtech's Avatar
Default how do i gut the afc housing?
wats the rudown? wats the pros and cons to it
Old Jul 12, 2009 | 06:40 PM
392hemix's Avatar
Well, for a street truck, i would keep it tuned, if you gut it, you will have to much lowend fuel. to gut it you take the foot, and plate out. and the diaphram, everything in the afc that can be taken out take it out. you can try it, and see how you like it, and if you think its too much fuel just put it back togeather.
Old Jul 12, 2009 | 06:52 PM
94 12valve's Avatar
why oh why would you wanna gut you afc?
Old Jul 12, 2009 | 08:31 PM
bowtech's Avatar
just didnt know the run down on sounds of it dont want to just tryin to figur out hoe to tune it good bc the star wheel is turned all the way up so from a dead stop it smokes alot from a dead start so if i turn it down till its just a lil black smoke thats the good spot? some one explain how to tune the afc or wat ever it is
Old Jul 12, 2009 | 09:48 PM
392hemix's Avatar
Well, its not the most simple thing to get dialed in, you have to work @ it. There is a few different adjustments. Firts, you have your plate setting, most ppl, have ot full forward, and then you have the people who put it 1/8 back from full forward, ect. this is all personal prefrance and depends on your plate and use of truck. Then like the plate you can slide the housing of the AFC (air fuel control) forward or back, like the plate, once again giving you your desierd feel. FYI, everything fully forward (Front of Truck) is max fuel. Then there is your star wheel, which controls pre boost fuel, you can turn that twards the engine, giving you more fuel or tward the fender for less fuel (PRE BOOST). what you normally want to do is teset and tune, do some adjustments and see how the truck reacts, if you stomp on the diesel pedal, and the truck hesitates to boost and bogs, Blacks smokes out the road, turn the star wheel back twards the fender ECT ECT. Do you kinda understand? basically you need to spend some time here, just playing around untill you get it were you want it. its really not that dificult, just time consuming. Im sure people will chime in here, that are more knowledgeable than I, and can give you some helpful hints, these are just some of the basic adjustments that any one with 2 hands and some tools can figure out and do. Good luck fella.
BTW, whats your truck doing?
Old Jul 12, 2009 | 11:05 PM
bowtech's Avatar
its just alot of black smoke pre boost so i figure if i turn the starwheel back a lil it will lower the egts help with mpg if i turn it to where it just black smokes a lil bit. with is the thing i slide for the more air?
Old Jul 13, 2009 | 10:45 AM
392hemix's Avatar
nothing gives you more air, just less fuel, which inturnes gives you more air than fuel, but not more air. Just turn your star wheel back some, and see how you like it.
Old Jul 13, 2009 | 10:52 AM
bowtech's Avatar
o my bad i miss understood you i will today thanks for the help bro
jeffersonl
Nov 15, 2015 07:35 PM
D-350 dually
Apr 11, 2015 11:38 PM
xj_crawler
12
Nov 20, 2014 10:17 PM
SMatyac
Nov 4, 2014 10:29 PM
jeffersonl
Oct 25, 2014 06:46 AM
