Fuel guage / speedo
Old Jul 12, 2009 | 05:28 PM
91cumminsboy's Avatar
Default Fuel guage / speedo
ok i bought this 91 about a year ago and weve just bout tried everything on the speedo new vss the wire hot and the fuel guage ive tried new guage cluster and the same so i could use a little help its just them to not workin
Old Jul 14, 2009 | 12:06 PM
does anyone know bout either bc i bought a gps foe the speedo now i just need the fuel
Old Jul 14, 2009 | 05:17 PM
RSWORDS's Avatar
whats it doing? Not working? Start checking grounds. The ground wire from the battery negative to the radiator core support is under sized from the factory and gets eaten up over time. It plays all sorts of havoc with the gauge cluster. other then that check the sending unit in the tank and start following wires from there.
Old Jul 14, 2009 | 08:00 PM
thanks i appreciate it alot ill check into that tomm
Old Jul 16, 2009 | 04:32 PM
ok check the ground wire and it seems fine so goin check the sending unit sometime this week
Old Jul 16, 2009 | 04:34 PM
RSWORDS's Avatar
dont just check it, they are undersized I would remlace it with a larger wire anyway. Mine looked fine put with all the other stuff on the elec system (like gauges) it was hurting it.
Its probably time for a new sending unit in the tank.
Old Jul 17, 2009 | 02:51 PM
yeah it was the sending unit float was cracked thanks alot
Old Jul 17, 2009 | 03:01 PM
RSWORDS's Avatar
glad yuo got it fixed!
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
