what does the star wheel affect?
Old Jul 11, 2009 | 12:23 AM
bowtech's Avatar
Default what does the star wheel affect?
the star wheel is pre boost fuel right? so if my wheel is turned all the way and i turn it back some it will help with egt and mpg? does it do any thing for after the turbo?
Old Jul 11, 2009 | 12:32 AM
stkdram55's Avatar
for after the turbo?? what do ya mean...
but yes i believe it does effect you bottom end, if you can tune it right to add just the right amount of fuel then yes it will help
Old Jul 11, 2009 | 01:22 AM
bowtech's Avatar
like after the turbo spools up like on the top end of power
how do i know if its good just turn it down till it dont black smoke as much?
Old Jul 11, 2009 | 02:30 AM
89silverbullet's Avatar
yeah it effects how much fuel goes where in your rpms so if it all the way out then its got less at top.
Old Jul 11, 2009 | 08:49 AM
kyle_truck_pull's Avatar
i gutted my afc housing, i took the diaphram out and plugged the holes off and gained 40 hp on the dyno.
Old Jul 11, 2009 | 10:45 AM
bowtech's Avatar
how do you do that? but does it smoke more?
Old Jul 12, 2009 | 02:12 PM
bowtech's Avatar
it was already turned all the way when i got the truck to adjust it do i just take out the big allen wrech colt on top?
Old Jul 12, 2009 | 06:35 PM
392hemix's Avatar
Ya, its a plug, just pop that little guy off, and turn the star wheel, which looks like a drum brake adjuster twards the engine for more pre boost fuel, and twards the fender for less pre boost fuel. I know if you have too much fuel down low the truck will bog, and smoke like a train, so you need to figure out if you like to smoke ppl out, or get a jump off the line.
Old Jul 13, 2009 | 12:03 AM
bowtech's Avatar
so how do i make it to get a better jump off the line? i poped it out once and i didnt see the wheel just the spring on the metal pin or wat ever wats up with that?
Old Jul 13, 2009 | 10:38 AM
392hemix's Avatar
your wheel has been turned to far, just take the afc off and flip it upsidedown, you can see it from there and get it back into the hole. no bid deal
