i got problems
Old Jul 10, 2009 | 09:57 PM
dodge rodder's Avatar
Default i got problems
can some one tell me what i have done wrong. this is the first time i have done a set of injectors. it is missing bad on 1 hole at low speed, but fires at higher speed. any info would be very helpful.
Old Jul 10, 2009 | 10:01 PM
stkdram55's Avatar
did you buy nozzles or whole injectors...if you got just nozzles then youshould of get them pop tested once you installed them into the injector body...if you did not then that is where you miss is coming from...if you did whole injectors then you probably didnt get the crossover tube seated right, check the line going to that cylinder and also that the crossover tube is seated properly
Old Jul 10, 2009 | 10:07 PM
i got the whole injector (rv275). how would i check for witch cylender the miss is in or would it be better to pull them all out and start over. did not have this problem before
i put in the new ones.
Old Jul 10, 2009 | 10:14 PM
Benjamin's Avatar
Bombardier
you can get an infared temp gun and read each exhaust port temp on the exhaust manifold. that will tell you where the bad injector is.
Old Jul 10, 2009 | 10:22 PM
sidekick's Avatar
use the temp gun and look for the cool cylinder
Old Jul 10, 2009 | 10:24 PM
Sounds like a bad injector.... New or Used?
Old Jul 10, 2009 | 10:34 PM
stkdram55's Avatar
if you use a temp gun you have to get it pretty close to the head to actually find one that is cooler then the others, i would crack the lines one at a time and it should sound different until you find the one that isnt firing then it will sound the same...how long has it been doing this?? If its the first time you started it after installing the new injectors then there might jsut be air in the system and it will work its self out in a few minutes...
Old Jul 10, 2009 | 10:45 PM
Benjamin's Avatar
Bombardier
if he lets the truck get completely cool and cranks it up in a matter of seconds he should either be able to feel by hand or use the gun to tell which cyl is not firing and is "skipping".....
Old Jul 11, 2009 | 03:13 AM
Uncle Bubba's Avatar
Check injector number 6 and make sure you got the injector fuel line tight. It's tough to get to so for some reason it's a common problem to not get it tightened down and it makes this exact lopey idle your talkin about.
Old Jul 11, 2009 | 10:28 PM
guys, i give my self the dumb *** award of the week. The copper ring fell of the bottom
injector some time before i put them in. i found them in the floor of the shop this morning and put them in and its a striped assed monkey. all the info is very much
Appreciated. THANKS
Zachbishop
Feb 10, 2015 10:23 AM
Ol Goat
Jan 22, 2015 02:16 AM
ChgoSquad5
Ford Powerstroke 2011-Up 6.7L
Jan 6, 2015 11:37 PM
Tucker126
Jan 2, 2015 08:09 AM
yams
Audio Equipment/Electrical
Nov 29, 2014 09:25 PM
