Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
turbo questions???
Old Jul 10, 2009 | 06:04 PM
biscuit87's Avatar
Default turbo questions???
ok guys so here is my question! im from florida and the sled pull scene isnt big or no where even close to being as serious as other places and the rules for there are nothing like up north and stuff!! any ways here is the deal i have a 93 4x4 3500 and im trying to decide between doing a big single or compounds! but from what i have been reading compounds put you into like the outlaw class where its the "big boys" so to speak! can anyone tell me the rules as far as turbos and the classes??? thanks guys it would be a huge huge help!
Old Jul 10, 2009 | 08:11 PM
HoodStacked's Avatar
Banned
Classes Usually Go work stock, 2.6, 2.8, 3.0, 3.2 Twin, and Modified.
Work Stock-Stock "appearing" Turbo,
2.6-2.6" Single Charger, sometimes called the street class
2.8-2.8" Single Charger, Usually Stock driveline(no drop boxes or Rockwell axles)
3.0-3.0" Single Charger, Depending on region can be Unlimited Driveline
"Prostock/Prostreet"- Usually Unlimited Single or 3.0 or 3.2 Twin Turbo
3.2 Twin-3.2" Twin Turbo, Similar To Prostock
Modified- Cut tires Unlimited Chargers, Unlimited Driveline, Mega HP
Your best bet would be Workstock or 2.6". Not sure of your competition down there, but a typical 2.6" truck up here usually has $10,000-$15,000+ in Mods. However if competition is scarce, you should be competitive with a 14mm Injection Pump head, A set of Injectors and a good turbo along with Tranny mods and Intake/Exhaust. This should put you 350-400 Hp. A set of Injectors from a non-intercooled cummins should support this HP level.
Old Jul 10, 2009 | 10:31 PM
sidekick's Avatar
x2
Old Jul 11, 2009 | 09:47 AM
Banned
Hey dont feel bad sidekick, i currently have a broken tibula and fibula.
Old Jul 11, 2009 | 11:22 AM
LOGANSTANFORTH's Avatar
i originally had a good set of rules for those trucks but they screwed them away when Greene's took it over because i was too strict with the rules they said, i run a tight ship and keep it that way and had everything fair, they got 2 classes, stock turbo, then everything else.....and by stock turbo they mean bone stock, not a stock cummins turbo off a 6.7 on a 1st gen, the turbo has to match the make and model of the truck.....yes, i know it sucks.....and if you step up to the big class your gonna get it handed to you with a 1st gen unless your willing to drop some cash, big turbo, 4000 GSK, big sticks, built tranny and other stuff.......so until i or someone else can buy a sled and start putting on pulls your pretty much stuck using keiths junk rules, so i would just recommend going out and having fun and not worrying about winning cause as long as there is a stock turbo dmax in that class you wont win unless he breaks or dosent show......
by the way, do i sound a little angry???
Old Jul 20, 2009 | 02:39 AM
biscuit87's Avatar
just a little it is kinda shitty i remeber when my pops and stuff took me to a couple when they first started out it was all about having fun and having a good time and what not it seems now its a money sport! but hey its all good ill be happy cause i paid next to nothing and the guy with that d-max or powerstroke paid a good 40 to 45 g's more then me haha and 15 years newer! anyways where are you from hood stack whats your location? im almost done with my cummins trainging for gen-tech and there asking me where i want to go! and well i want to go where the sled pulls are everywhere! haha! anyways thanks alot for the help and advice guys looks like ill just ahve to go find some good ole old timers to help me get every little last drop of fuel out of that VE! and where are the turbos measured? like how do i go about measuring a turbo to find the specs? i got like a 12 different turbos just sitting at the shop collecting dust so i guess its time to start figuring which one to go with! and do you guys recomend any?
thanks alot for all yalls help i really appreciate it!
Old Jul 20, 2009 | 05:33 AM
they are measured off the intake (cold side) inducer (the area right around where the intake wheel is at), your typical classes for measured turbo's are 2.5 (class is getting smaller cause no off the shelf 2.5 turbo exists), 2.6in/66mm (took over the 2.5 class cause they are easily bought off the shelf, i wrote that rule back in late 07 cause of that reason and other people started to catch on after that), 2.8 (K31 Borg-Warner, ATS Aurora 5000 sized turbos), 3.0 (HT60 and that type, usually from Semi trucks and equipment).......about everybody and their brother now offers a 2.6 legal turbo of some sort.......Though you can buy off the shelf Borg-Warner units that will work good on most trucks, like an S366....its a S300 frame with a 66mm inducer bore, most guys are going to run a S400 frame turbo (S465 is the hot ticket right now) to be at the top of the class and most likely that turbo will have a custom wheel in it with a ported housing and all the rest of the aftermarket stuff, the flange size is something you also need to take into consideration, you can have a T3 or T4 flange (sometimes you have a T6 on a S400 but its very uncommon), a T3 is what a factory dodge manifold is, a T4 is about an inch bigger in all directions, you can either use an adapter plate (50$ from most machine shops) or you can buy a aftermarket exhaust manifold from a few companies with the bigger T4 flange, they are also available in the T3 flange.....if you want to win, get a custom S400 built for about 1800 bucks and up, some turbos can run upwards of 5K, if you want to have fun, get a brand new "stock" S366 or S464 for about 900 bucks and go have fun......
Old Jul 21, 2009 | 01:23 AM
biscuit87's Avatar
ok awsome thanks man!
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
markanthonyhudson
11
Feb 11, 2015 05:49 PM
GreenDieselF
Oct 20, 2014 02:05 PM
