advance timming with out the dial indicator method
Old Jul 9, 2009 | 09:53 PM
kyle_truck_pull's Avatar
Exclamation advance timming with out the dial indicator method
what is the procedure for advancing the timming without the tools required to check the plunger lift? how far do you know how to move it and which way do you go? do you leave the pump and take it loose from the motor, and then turn the motor with the pump loose and then retighten it down? can some one explain it a little better for me? thanks!
Old Jul 9, 2009 | 11:36 PM
oglejust's Avatar
timing - TheDieselGarage.com
