fuel shut off silenoid
Old Jul 9, 2009 | 06:14 PM
regor's Avatar
Default fuel shut off silenoid
Does any body know where i can get the fuel shut off silenoid for the ve pump i am in need of one, bosch # 0 330 001 040, i put the 3200 spring in and everything was great until i hit the manual cut off and then restarted the truck and then it wouldn't cut off by the key anymore and i have checked the voltage to it getting 12 volts when the key is on and nothing with it off, anybody know where i can get one other then the dealership?
Old Jul 9, 2009 | 06:17 PM
RSWORDS's Avatar
$10 Magnetic Valve (Start/Stop Solenoid) for VW Diesel Injector Pumps. VW Diesel TDI
Old Jul 9, 2009 | 06:20 PM
RSWORDS's Avatar
Or you can get it at NAPA
Be warned though that with a turned up pump and stock I/C'ed injectors its only a matter of time before it gets chewn up again.
Old Jul 9, 2009 | 06:23 PM
regor's Avatar
Thanks RS you have been a great help
Old Jul 10, 2009 | 07:40 PM
regor's Avatar
Well i found a soleniod for the truck can you beleave that the dodge dealership didn't even know what i was talking about and couldn't help me even with the part # napa could have got it next week for me. i ended up driving fifty miles to get it from a pump repair shop in the big city. oh well everything was going well until i went to change it, i bent a wrench just to get to it and low and behold somebody over torqed it and i couldn't get it out had to take the whole top of the pump off and grind down a socket and drive it on there after taking a file to the pump housing and finally broke it loose. But the truck is back up and running like new, and i found a place to get my parts from.
Old Jul 11, 2009 | 09:09 AM
stillcummin's Avatar
why would they get chewed up?this is up out of the way while running
Old Jul 11, 2009 | 08:15 PM
regor's Avatar
I guess when you shut it down with the pump being turned up its more pressur against the plunger and it wears it out quicker, but i have two more solenoids coming so i will not have to hunt for one next time just put it in.
Old Jul 11, 2009 | 09:02 PM
RSWORDS's Avatar
The back rush of all te\he extra fuel from the turned up pump wears it out. Its not really a problem on the non-I/Ced trucks (they have larger stock injectors) just the I/Ced trucks with stock injectors.
Old Aug 19, 2009 | 11:28 PM
willyC93's Avatar
Default fuel shutoff solenoid
I added the 3200 spring and turned up the pump on my 93 IC and went througt 2 fuel solenoid plunger fast! Now have a manual cable shutoff because I don't know where all the rubber goes. I found some of it in the return banjo screen, but have not found the other
2/3s, and I'm afraid to look further. I want bigger injectors anyway.Good Luck with all of your extra solenoids.
Old Feb 6, 2010 | 05:23 PM
schamran's Avatar
Wow. I just paid like $95 for one. Dammit
