nv4500 tranny fluid
Old Jul 9, 2009 | 10:21 AM
94cummins12v's Avatar
Default nv4500 tranny fluid
i know the nv4500 is suposed to take castrol syntorque 75w-90 oil. napa dont carry it here. isnt it just a synthetic oil? why wouldnt valvoline full synthetic 75-90 gear oil work
Old Jul 9, 2009 | 10:29 AM
FastCR's Avatar
different ratings. you NEED the right fluid or it will take out the trans. You have to get it from chev, dodge, or ams.
Old Jul 9, 2009 | 01:18 PM
well im going to run the valvoline stuff for this trip. ive been running the catrol 80-90 gear oil hypoy c for years so the full synthetic wont hurt for 1000 miles, then ill get the good stuff when i get back
Old Jul 9, 2009 | 01:59 PM
FastCR's Avatar
yeah. its when the fluid starts to break down that it start messing **** up. There's a writeup on dodgeram.org i think.
Old Jul 9, 2009 | 02:38 PM
kazairl's Avatar
from what I understand the Nv4500 reguires a GL-4 fluid. The Valvoline is a GL-5 which has a higher sulfer content. From what I understand the higher sulfer content attacks the yellow metal peices(syncros). However heat also plays a factor. The syncros are in more danger with higher heat because the heat speeds up the process. However a gl-5 fluid runs cooler than a gl-4 so I don't know.
FWIW my dad uses the valvoline stuff and we just replaced his tranny at 300k. Mostly because 3rd gear syncro was gone( it always ground going into gear) and he ended up loosing reverse. They don't carry the Castrol stuff around here either and the Mopar stuff is expensive as hell.
Old Jul 9, 2009 | 03:57 PM
No its not - Castrol is the only oil thats meant to be used with the carbon fiber synchros in the NV-4500.
Using anything else risks a teardown.
Old Jul 9, 2009 | 04:06 PM
FastCR's Avatar
its carbon fiber? coooooool. I'ma start sportin that
Old Jul 9, 2009 | 04:17 PM
No...not carbon fiber. Had a brain fart.
But they are some sort of fiber and are not the bronze/brass ones like in the NV5600.
Quad4x4 Home sells the oil and the shipping shouldnt be bad for Brandon since they are in Montana.
Some interesting reading here: QUAD 4 x4
Old Jul 9, 2009 | 06:21 PM
Heath's Avatar
Authorized Amsoil Dealer
We also have one that is made for the NV4500:
gear lube
This is what I used in mine.
Old Jul 9, 2009 | 07:52 PM
Riflemanusmc's Avatar
Cart
I'm right up the road from Quad4x4. Any member here needs parts fast, let me know....
