ID transfer case
Old Jun 21, 2007 | 02:38 PM
Heath's Avatar
Authorized Amsoil Dealer
Default ID transfer case
Looking at a 2002 CTD. My reference guide list 2 possible transfer cases, a NV241 and an NV241HD.
Any simple way to tell which you have?
Heath
Old Jun 21, 2007 | 02:43 PM
ndurbin's Avatar
The NV241D is a heavier duty Dodge version of the 241, with a larger input shaft and larger bearings to withstand the torque of the V10 and diesel engines.
The NV241HD, an option on Ram 2500's and standard on Ram 3500's built after 1998, has a stronger case and wider drive chain to better withstand the shock of snow plow service, a PTO cover and drive gear, and an extra bearing to support the thrust to the main shaft created by a PTO adapter.
Except for dimensional differences and the PTO port on the NV241HD, all of the cases are almost identical in appearance. An identification tag is attached to the rear case of every transfer case. The tag provides the transfer case model number, assembly number, serial number, and low range ratio. The transfer case serial number also provides the date of build. For example, a serial number of 9-10-93 would represent September 10, 1993.
Took that from Dodgeram.org
Old Jun 21, 2007 | 02:48 PM
Heath's Avatar
I figured it would require crawling under there
Thanks Nate.
Old Jun 21, 2007 | 02:57 PM
DB Admin's Avatar
Banned
Im going to check mine out , I know mines stock also I guess ill be ordering some more Amsoil Heath ..LOL
DM
Old Jun 22, 2007 | 04:57 PM
DB Admin's Avatar
Banned
Mines a 241 DHD , Anyone know how to drain it and fill it?
Old Jun 22, 2007 | 05:02 PM
Heath's Avatar
I guess I have the 241. On mine there are two plugs on the rear side, one at the bottom and one about 3/4 of the way up. I drained from the bottom and filled til it leaked out the top. Not sure if that was correct, but it worked
Old Jun 22, 2007 | 05:19 PM
Whit's Avatar
Site Mascot
Ya drain plug on the bottom...........I bought me a lil pump to hook on the end of my drill......used many times for crap like this....works real good
Jrod89
Feb 24, 2015 09:48 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
miked2805
Oct 19, 2014 11:02 PM
steves2500diesel
Oct 14, 2014 05:36 PM
