Killer dowel pin
Old Jul 8, 2009 | 09:12 PM
Overload's Avatar
Default Killer dowel pin
I took the front cover off my motor and saw the pin was stickin out half way, this is after 200,000 miles on it, scary. Anyways, took a piece of steel and made a "cap" to retain the pin like the ones you can buy. My fear is now that the aluminum case might expand and the retainer will rotate down into the gear train. I can see that it will but I saw the ones you buy fit the entire "cone" shape of pin area. My bolt is torqued and thread loc'd, but still, anyone else made one and had any issue like this? I hate to take the front cover off, but hate even more to be stuck in Kentucky with Banjo music.
Old Jul 8, 2009 | 09:18 PM
Did you use red loctite on the bolt?
Old Jul 8, 2009 | 09:34 PM
Overload's Avatar
Yes, Im worried more that the aluminum will expand and the retainer I made will rotate, I was banking on the radius of the edge to retain it but I see that the professional kits go the entire way into the cavity, mine covers half the dowel pins face.
Your saying red loctite will not back out from vibrations, only torque
Old Jul 8, 2009 | 09:37 PM
Should be quite easy to pull it back apart and make sure its ok. You should also loctite the other bolts in the case.
Old Jul 8, 2009 | 09:45 PM
Overload's Avatar
Yes, I have already made up my mind to do it tmorrow, was simply hoping to get the truck back on the road tomorrow, but no point doing it half ace.
Aug 25, 2015 07:10 PM
windage
Jul 17, 2015 12:45 PM
Weeks327
May 11, 2015 10:43 AM
359ci12v
Apr 9, 2015 08:24 AM
dieseldeal
Mar 24, 2015 12:11 AM
