Turning my exhaust manifold 180 degree
Old Jul 7, 2009 | 10:23 PM
Overload's Avatar
Default Turning my exhaust manifold 180 degree
Im cleaning up my motor for the Dodge and have decided to flip my exhaust manifold 180 so that my turbo sits on top of it, rather than hang, I'm going to make a fiberglass scoop and stack the exhaust right out of the hood. Question is, will the stock oil pump send enough oil to the turbo for lube or do I need to upgrade?
Attached Thumbnails Turning my exhaust manifold 180 degree-diesel-engine-006.jpg
Old Jul 7, 2009 | 10:48 PM
12valvetater's Avatar
yes but the line may not be long enough many people have the charger on top becuase thats what it takes to run twins
Old Jul 7, 2009 | 10:49 PM
davo79's Avatar
Dot law says the exhuast must exit behind the cab and cannot turn out between 2 and 8 feet so unless you're building a pulling truck I wouldn't run it out the hood as far as the stock oil pump is concerned your turbo is still mounted the same wether its hung or sits on top and considering that the guys running twins still use the stock pump it should be enough to oil it
Old Jul 8, 2009 | 07:44 AM
Overload's Avatar
Davo, thanks for the concern, but I'm not really concerned law wise, just motor longevity wise.
Davo, Just to find out what your talking about legality wise I checked the DOT, Ohio DOT, DMV, and several other sites. I was unable to find any information regarding exhaust placement, can you send me the literature you have regarding this?
From what I found we simply cant have straight pipes, and need to not emit excessive smoke.. My solution is going to be run dual tractor stacks, if you look at the video attached to my profile, I have already done this to an old crapper Ford diesel to see how it would work, now Dual will really be slick.
Old Jul 8, 2009 | 10:07 AM
AF1CUMMINS's Avatar
I went to your profile and didn't see any video
Old Jul 8, 2009 | 10:57 AM
FastCR's Avatar
must vary state to state. in MT and i believe down here too, it has to exit rear of the cab OR upwards.
Old Jul 8, 2009 | 11:12 AM
Hammer's Avatar
Now thats a good way to think and a good way to hurt your wallet.
There is nothing to be gained from flipping the manifold performance wise or longevitywise that would warrant you to flip it as a single.Many owners flip their aftermarket manifold to allow for placement of twins but in a single configuration they are hung like the factory hangs them.There is no oiling system upgrade needed when a owner flips the manifold for twins either.
Old Jul 8, 2009 | 01:49 PM
davo79's Avatar
It does vary state to state I know california is **** about stuff like this
Old Jul 8, 2009 | 09:06 PM
Overload's Avatar
I was working on it tonight but now noticed my oil drain on turbo is upside down, and if I flip the middle, I then loose my waste gate acuator. Will have to go back to stock anyways.
Old Jul 8, 2009 | 09:39 PM
clock it
