Adam's Polishes Visit - Adam's Polishes
Adam's New Spot Pad Buffing System
Old Jul 7, 2009 | 09:54 AM
Nitelord's Avatar
Default Adam's New Spot Pad Buffing System
Why have a 4" Buffing Pad system when our 7.5" system is so successful? Easy: Using the Spot Pad System on a cordless drill creates a mini-rotary-buffer, which can easily remove surface scratches, restore dulled headlamps, and eliminate hard water stains from glass.
Install the adapter on the Porter Cable, and go straight over the area for a perfect, showroom shine!
The Yellow Spot pad is for removing severe water spots, oxidization from headlamps, or for removing deeper scratches from your clear coat.
The Orange is the same foam as our Swirl Killer Pad. Extremely effective, and a great way to remove a minor scuff from your finish, safely.
Our White Spot Pad is a fine polishing pad, and can also be used for polishing hard to reach areas with the Porter Cable, as well as the cordless drill.
Finish off the are with our black Spot Pad and you will be amazed at what can be accomplished!
NOTE: This is a buffer, and can burn the finish if not extremely careful.
Adam's 4 Inch Focus Pads Headlight Restoration and Scratch Removal
