Uh-oh...?
Old Jul 6, 2009 | 09:26 PM
FarmDiesel's Avatar
Exclamation Uh-oh...?
I was under my truck switching it from BADP exhaust to SMARTY exhaust wiring... And I noticed that my transmission was somewhat oil coated. It never has leaked enough to make it to the driveway, but it is coated in oil.... Any ideas?
Old Jul 6, 2009 | 10:31 PM
Woody35's Avatar
gasket gone bad? oil cooler lines leaking? connection of some sort leaking?
Old Jul 6, 2009 | 10:35 PM
wildbill's Avatar
New engine sounds like. Good luck with warranty.
Old Jul 6, 2009 | 10:51 PM
FarmDiesel's Avatar
I had a clutch installed. Dont know if they had to mess with the transmission when they did it.
I did notice some silicon on an access door or something to the transmission. Doubt they use that at the factory.
Old Jul 7, 2009 | 12:54 AM
ETXBlueRam's Avatar
Just a thought, but you might look up under the front of your engine and see if the front crank seal is leaking. I had to have mine replaced about 6 months ago. Noticed it was leaking when I was changing my oil.
Old Jul 7, 2009 | 08:22 PM
Red_Rattler's Avatar
High Tech Redneck
First things frist, degrease everything and run her as normal and at the end of the day crawl under and see where its seeping from. Good luck bud
Old Jul 7, 2009 | 09:06 PM
FarmDiesel's Avatar
I looked all under the truck, and the oil is ONLY coming from somewhere near the top of the transmission.
Old Jul 7, 2009 | 09:11 PM
High Tech Redneck
Sounds like it got over filled
Old Jul 8, 2009 | 10:03 PM
brk126's Avatar
just noticed mine doing the same thing.......havent had time to really get into it....dont think is from the tranny they run ATF in them from the factory and the stuff leaking is not red so idk..looks kinda like fresh oil....
Old Jul 9, 2009 | 12:18 AM
FarmDiesel's Avatar
