Turbo removal difficulty
Old Jul 6, 2009 | 04:13 PM
Begle1's Avatar
Default Turbo removal difficulty
Unbolt the four bolts holding on the turbo.
Turbo falls.
Turbo hits frame rail before it clears mounting studs.
How does one get the turbo out from in between the mounting studs and the frame rail? Do the mounting studs press out? Or do you have to get creative and roll it out somehow?
Old Jul 6, 2009 | 04:21 PM
wildbill's Avatar
What year truck??
Old Jul 6, 2009 | 05:11 PM
LOGANSTANFORTH's Avatar
3rd gen im assuming.....
Old Jul 6, 2009 | 05:15 PM
Begle1's Avatar
Third gen 5.9 liter.
Old Jul 6, 2009 | 06:58 PM
wildbill's Avatar
Easiest to pull with the exhaust manifold.
Old Jul 6, 2009 | 08:05 PM
Begle1's Avatar
Seriously?
Wow, that's a retarded-epic pain.
Old Jul 6, 2009 | 08:09 PM
Benjamin's Avatar
Bombardier
that is what i was gonna suggest, it is only 12 bolts.... i used an impact on mine to R&R... granted it is a 12v and not a 3rd gen....
Old Jul 6, 2009 | 08:33 PM
sidekick's Avatar
the outside two studs unscrew and that clears the turbo to twist out a pair of bent nose channel lock pliers will grab and extract the studs easy. Just let turbo fall as far as it will and the slide the pliers between the manifold and the turbo.
Old Jul 6, 2009 | 08:53 PM
Begle1's Avatar
Other year trucks are like this too?
So do you thread out the outer mounting studs or press them out?
I never knew I was this spoiled with a first gen.
Old Jul 6, 2009 | 09:06 PM
Benjamin's Avatar
Bombardier
no, as far as i know every other cummins is center mounted, only the third gens are rear mounted down up in there.....
