CRANK CASE VENT
Old Jul 5, 2009 | 02:43 PM
redwood logger's Avatar
Default CRANK CASE VENT
is there a simple way to check if my crank case vent is plugged? should it be sucking air or blowing air out (talking about the hose coming down by the oil pan)
Old Jul 5, 2009 | 02:46 PM
stkdram55's Avatar
should feel a little bit coming out, shouldnt be a whole lot but should definately be blowing
Old Jul 5, 2009 | 02:47 PM
Thanks I will check it out
Old Jul 5, 2009 | 04:05 PM
Uncle Bubba's Avatar
Hood a piece of paper under it that way you can see any oil blow and see if it's sucking wind in or bowing it out.
Old Jul 5, 2009 | 10:18 PM
The vent is doing so little its hard to tell. but if anything it seems like it might be sucking in. If it is its just barely. Even with the piece of paper I could not see anything happening.
Old Jul 5, 2009 | 10:19 PM
Begle1's Avatar
If you can notice more coming out of the fill port or dipstick than the vent, then something might be amiss.
Old Jul 5, 2009 | 10:24 PM
Good idea, I will check that. Thanks
Old Jul 5, 2009 | 10:29 PM
stkdram55's Avatar
Is there a reason you are checking the blow by on your engine?? or just pure curiosity
Old Jul 5, 2009 | 10:35 PM
Ya, the rear main is leaking, so I have heard a plugged vent can cause that.
Old Jul 5, 2009 | 10:36 PM
stkdram55's Avatar
alright, just wandering...that makes sense that a plugged vent could cause a rear main
