w250 suspension sagging x-cab 92
Old Jul 4, 2009 | 02:21 AM
Azrattler's Avatar
Default w250 suspension sagging x-cab 92
the front left leaf seemed to be saggin a bit.. i purchased the skyjacker 2 1/2 lift kit for it installed the fronts spring and shocks....well the front seems to be pretty much level now...but noticed the back left to be lower also..the lift kit came with add a leafs for the rear but there is no point in putting them on yet if i have to get new leafs or newer leafs...is this a problem with these trucks usually..it has 236k miles on it and has a gooseneck hitch so someone down the line use to pull with it..
which rear leafs will bolt up directly from a newer gen truck and keep the same ride hight?
thanks
Old Jul 4, 2009 | 06:17 AM
LOGANSTANFORTH's Avatar
you should be able to get about any spring pack you want made brand new for only a couple hundred from a spring shop.....if getting new ones made make sure you get more thin leaves than the stock pack, it will keep the same height or a little more and ride ALOT better, Skyjacker springs have always had a problem with sagging, wether it be coild or leaf, gas or diesel......
Old Jul 4, 2009 | 07:35 AM
sidekick's Avatar
just tell the spring shop what arch you need and the mesurement center of mount hole to center mount hole
Old Jul 4, 2009 | 11:09 AM
Azrattler's Avatar
thanks for the replys guys but the skyjacker springs i just put on last night..so they arent sagging yet ...but the rear left spring now seems to be saggin it is the stock spring still..will any of the newer gen spring fit in there without any mods..cause i want to try and get it fixed today if i can....
Old Jul 4, 2009 | 11:17 AM
stkdram55's Avatar
check to make sure none of the springs are cracked in the pack, chances are that is your problem one is cracked and you cannot see it...i doubt that any of the springs from the newer trucks will fit..different axles and what not
Old Jul 4, 2009 | 11:22 AM
Azrattler's Avatar
alright thanks guys ill check it out more now that it is daylight and see what i find..
scubasegt
Jun 9, 2015 12:07 PM
carid
Diesel Bombers Sponsors
Apr 22, 2015 09:28 AM
torino73
Apr 14, 2015 11:15 PM
RHIT_Cummins
Dec 16, 2014 10:14 AM
Jthompson_32
Oct 5, 2014 09:51 PM
