How exactly do you install a EGT, tranny fuel pressure and boost gauge?
Old Jul 3, 2009 | 10:42 PM
'91 D350's Avatar
Default How exactly do you install a EGT, tranny fuel pressure and boost gauge?
It has been recommended to me that I install all these gauges before I go wild in turning my truck up.
Can anyone give me step by step instructions on how to do it properly?
I also need to know how to wire them, and where to splice into if I need to do that. I have been told that a lot of people use the cigarette lighter as their power source. Well mine doesn't work, I think it is a blown fuse, so how exactly do i change fuses on these trucks? How can I tell where the cigarette lighter fuse is? (sorry, this is my first time dealing with electrical things, and diesels.)
Thanks guys!
Old Jul 3, 2009 | 11:28 PM
jasonfriedlin's Avatar
i wouldnt use the cigarette lighter as a power source. Try to drill your hole for the exhaust probe before the turbo if you can. For the boost gauge, there is a place to hook it into, I just cant remember where. Somebody will chime in here and help out some more. Ive never done the tranny gauge so idk about that one
Old Jul 3, 2009 | 11:49 PM
stkdram55's Avatar
most of the guages come with instuctions to install them, like jason said tap the exhaust manifold before the turbo...there are plugs in the intake manifold for you use to hook up your boost guage, and i know on second gens there are plugs on the passenger side of the tranny for the guage to hook into...but i imagine the 1st gens are alot different and you may have to tap your tranny somewhere else for the guage
Old Jul 4, 2009 | 01:21 AM
LOGANSTANFORTH's Avatar
make sure before you go drilling a hole in the manifold you got some way to get the metal shavings out......grease a drill bit real good and drill the hole, then take something long and thin covered in grease and push it down into the hole and get the excess shavings out, then tap your hole with grease on the tap then clean up the rest of the shavings like stated above......then what very little is left will blow out the exhaust........
Old Jul 4, 2009 | 08:58 AM
RSWORDS's Avatar
For the EGT probe I have always just let the truck run while drilling and tapping. The manifold is cast and all the chunks get blown out and the little dust that comes off passes right through the turbo. At idle the turbo is spinning to slow for the metal dust to hurt it. Start with a small drill bit and work your way up to the size you need. Done this to alot of trucks and never had a problem.
The boost gauge goes in a plug that is on the drivers side of the engine behind the bracket for the throttle. You will need to pull it off and drill a hole. You can see were that brass tube I put in comes through the bracket and the hole I drilled. You don't need that tube I put it there because I needed to boost reference a couple different things. You can see teh boost line (white tube) coming in from teh right and the compression coupling it goes to. Just remove the plug on the head right behind were that hole is and put it there.
The tranny temp gauge will be fine in the pan. Pull the pan and weld a bung in there.
Old Sep 29, 2011 | 07:23 PM
coeboy's Avatar
anybody got a pic of the egt probe placement??
Old Sep 29, 2011 | 08:09 PM
chromehound's Avatar
Look to the left of the heater lines
My gauges were tapped into my cab visor for power for the lights
Old Sep 29, 2011 | 08:11 PM
coeboy's Avatar
ok i see now thanks i was going to put it in the down pipe. is there a differance in there compared to where you put it?
Old Sep 29, 2011 | 08:17 PM
For the tranny gauge I got a second pan and took it to my trans place and they put the bung that came with the gauge in facing the rear of the truck IIRC. I ran the copper line up through my 4x4 shifter with just a slight grinding of the ring around the shifter to avoid pinching.
It's more acurate pre-turbo as post turbo is ~200* or so cooler. There is still some debate as to which is better but I've always run pre-turbo. When you drill for the probe make sure you offset it towards the cab to avoid hitting the divider in the manifold and the #6 cylinder is supposed to run the hottest.
Last edited by chromehound; Sep 29, 2011 at 08:18 PM. Reason: Automerged Doublepost
Old Sep 29, 2011 | 08:21 PM
coeboy's Avatar
ok works for me will do first thing in am thanks everyone
