Death wobble. WT???
With 68000 miles, everything is factory tight. Checked and re checked. No factory sway bars our steering dampner...Really caught me off gaurd... Shook like hell, and was only doing about 40mph. Passed over, what I would call some mild road construction..Any idea's?
Logan, with only 68000 miles on this beater. The whole front end is tight...Tire's???? Some off brand POS's I'll take pic's of the tire's and post them...
Last edited by Riflemanusmc; Jul 3, 2009 at 10:11 PM. Reason: Automerged Doublepost
sounds like you really need to tear everything down and just inspect it......something in there isnt right to cause this......if something is setting alot like this truck has stuff goes bad more than if its drove every day,
another cause of those tires being worn is bad king pins in the axle......
Last edited by LOGANSTANFORTH; Jul 4, 2009 at 02:01 AM. Reason: Automerged Doublepost
U-joints wouldn't be turning if the hubs aren't locked/ t-case isn't engaged...
Check the frame around your steering box.... I had a '93 dually that had a cracked frame that made lots of problems...
