grinding the fuel plate
Old Jul 2, 2009 | 06:37 PM
bowtech's Avatar
Default grinding the fuel plate
can i grind my fuel plate flat like a 0 but not that far back kinda like a 100 but with out the curb on the bottom of the plate?
Old Jul 2, 2009 | 09:06 PM
Whit's Avatar
Site Mascot
yu can make it however you want
Old Jul 2, 2009 | 09:24 PM
bowtech's Avatar
so if i shaped it like a 0 but not as far back like with a stock plate and just grind the bottom off even with the top wat wood it make the plate?
Old Jul 2, 2009 | 09:52 PM
Whit's Avatar
Site Mascot
that would make it a bowtech special.................the best you can do out there is a 100.......easy on the drivetrain for take off then no holds barred from there
I would buil you a 100 but I aint been paid for the last 3 I did so I give it up
Old Jul 3, 2009 | 12:04 AM
bowtech's Avatar
so it fuels harder after take off?
Old Jul 3, 2009 | 07:21 AM
12valvetater's Avatar
yeah once the boost starts to build it comes up the flat and full fuel from there on youll like it
Old Jul 3, 2009 | 08:35 AM
tpcdrafting's Avatar
I ground my stock plate like a 100, but it starts at the bottom about 1/16" up and then ramps up to full forward real fast, then straight up from there. Makes 10#'s more boost (40 psi) than the #11 plate I had in there. Not to mention, it doesn't put the coals to it on the low end when I'm trying to excellerate with a trailer on, which in turn means lower egt's on excelleration and I can actually get up to speed a bit quicker. Knowing this now, I would never 'buy' a plate again. I carved this same plate for a guy at work for his '97 which is stock other than this plate and it really woke it up.
The best idea I've seen is to put it on a dyno, start off with a baseline, take out the plate and grind it a bit (while the truck is still on the dyno) and do this again and again until you get the best results. You may need a few extra plates around in case you grind too much.
Old Jul 3, 2009 | 12:50 PM
bowtech's Avatar
any pics that would mess up a stock tranni in a hurry yeah?
Old Jul 3, 2009 | 01:52 PM
Hammer's Avatar
I am at a loss when I see guys post about this home ground plate deal.
Think about it first.....
He has a 94 Automatic truck which he wants to drop a ground plate in.IF you look at the specs on what TST shows for plates then you should know that a 100(a 10 on the bottom and a 0 on top) will do him little good.The best performing plate for a 94 is a 5(unless you have a old 4 which they do not offer anymore) so why would you want to make his grind a 10 down low?.The only trucks which respond to the 10 down low is a stick truck.
If I was doing one for him it would be a 5 down low and the 0 up top.However,If he has nothing done to the transmission then anything you do is just a waste of energy.......Andy
Old Jul 3, 2009 | 03:00 PM
davo79's Avatar
I'm running a 0 in my auto and yea a 10 down low does about as much as a 0 down low except the smoke factor my truck smokes hard until I hit about 90 then its just a nice haze but the 10 down low should be clean and not build the heat in the low end but then again I might be wrong
