Exhaust Brake ?
Old Jul 1, 2009 | 07:25 PM
davo79's Avatar
Default Exhaust Brake ?
I've got a bd exhaust brake I just recently put on my 95 12v. Since I've put it on my abs light has come on my cruise control stopped working and my hvac only comes out the defrost vents its like the brake takes up all the vaccum anyone got any ideas on how to fix this maybe a vaccum booster or somethin
Old Jul 2, 2009 | 12:33 AM
94cummins12v's Avatar
thats odd when i had mine everything worked great but i went with a pacbrake
Old Jul 2, 2009 | 01:02 AM
sidekick's Avatar
hvac defaults to the defrost if there is a problem for safety problems cruise is probaly something with the abs not to sure it is all linked to the bd brake though is it messed up all the time or just when the brake is active
Old Jul 2, 2009 | 01:07 AM
not entirely true. if there is not enough vacuum to operate the vacuum servo for the heater controls then it will default to defrost. my guess is he forgot to hook up a line and its sucking air somewere, been there. check all you lines and conections. also the cruise is also vacuum operated so thats the same story as the controls lack of pressure would cuase the same thing
Old Jul 2, 2009 | 04:48 AM
davo79's Avatar
The abs is also run off of the vaccum I guess what I'm wondering is how can I boost the vaccum pressure so I can operate everything and know its not just when the brake is on it also doesn't seem to be working right checked all the connections and no leaks I'm lost on this one
Old Jul 2, 2009 | 11:49 AM
damn thats got me wondering now, no real wa to make more vacuum unless you used to big of line. what size line did you use
Old Jul 2, 2009 | 08:14 PM
davo79's Avatar
The 1/4 inch line it came with
Old Jul 3, 2009 | 08:30 PM
the only thing i can think of is a leak. if you leave it engagued does the heater vents work after time?
Old Jul 4, 2009 | 01:40 AM
jnicewan's Avatar
check for leaks again, does the brake work properly, was it used. might have a hole in the diaphragm, or one of the lines for the kit. its possible the vac pump is weak but when the bd kit activates it only uses enough vac supply to to fill the can to pull the valve closed and at this point the vac pressure should stabilize and become static but with a leak it will try to dump all vac pressure.
i have the same kit and nothing is wrong with mine.
Momo12valve
13
Nov 9, 2015 09:54 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
charlie175
Sep 1, 2015 04:01 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Turbo67
Jul 25, 2015 02:26 PM
