warped converter?
Old Jun 30, 2009 | 09:09 AM
CumminsKid6's Avatar
Default warped converter?
is it possible if i had to much power going through the stock coveter that itd build up enough heat to warp either the clutches or the converter itself. cause at a certain speed and rpm it vibrates real bad then goes away at about 60
Old Jun 30, 2009 | 09:37 AM
12vgonebad's Avatar
Do you even know what your talking about.
Old Jun 30, 2009 | 01:19 PM
01trailerpuller's Avatar
You did what I did. You burnt the torque converter. You will have to replace it. I suggest that you do a full upgrade including new cluches, input shaft, double deep pan and a new valve body. You can upgrade yours or buy a new trans. Upgrade runs about $5000-$6500 including labor and a new trans will run about $3500-$5500 plus labor and shipping in most cases. I did the upgrade with all BD parts and a torque converter locking switch for my exhaust break, and the exhaust break for $8500 installed. It sounds like a lot but my buddy only rebuilt his for $3500 and 2 years later had to rebuild it again. It is worth it to do it right the first time.
Old Jun 30, 2009 | 01:25 PM
well i rebuilt it once so me and my dad can do it and right know i dont have a whole lotta money so ill prob just get a converter from goerend. 1350 and a life time warranty. but thats what i thought it was. thanks for input
Old Jun 30, 2009 | 01:34 PM
No problem. Good Luck.
Old Jun 30, 2009 | 03:49 PM
Fishin2Deep4U's Avatar
Vibration at a specific speed is usually drive shaft or u-joint related. Check the carrier bearing first.
For a torque converter to warp to the point of vibration, the TC would probably no longer go into lockup. Also, the vibration wold be at the same RPM regardless of speed.
And for a TC to warp this badly, you would probably have already lost the pump and possibly the engine due to too much thrust on the crank.
Check the basic and most obvious stuff first. That's usually where the problem is at.
Dave
Old Jun 30, 2009 | 05:15 PM
With the 47re if you burn the torque converter will still lock up but will shake at certain speeds. I do agree with Fishin2Deep4U check the easy stuff first but it sounds just like what happened to mine.
Old Jul 30, 2009 | 12:29 PM
well its not carrier bearing cause short bed dont have one. and its not speed specific just when it locks up and matted then it goes away once it starts speedin up
alysiamc
Jun 19, 2015 02:03 PM
cumminsbred01
Feb 17, 2015 12:26 PM
Houstonautocore
Wanted To Buy (WTB) - Used
Dec 28, 2014 02:38 AM
Jgloveracob
For Sale
Dec 7, 2014 10:47 AM
Jeffreyjoe
Dec 3, 2014 06:01 PM
