Trans. Temperature
Old Jun 30, 2009 | 12:01 AM
BlackLB7's Avatar
Default Trans. Temperature
Anybody tell me what their avg. tranny temp is on a normal driving basis? again it is an LB7 allison automatic, and its been running from around 150 deg. to 200deg. and im not really comftortable with the fact that it is goin up to 200. help anyone?
Old Jun 30, 2009 | 11:55 AM
GTRW3T's Avatar
i have the lly w/ the allison and it normally stays between 150 and 190. the hotest it has ever been is 190
Old Jun 30, 2009 | 12:00 PM
REDRIDE13's Avatar
i will check the gauge on my way home from work tom and let you know.
Old Jun 30, 2009 | 05:35 PM
2500HeavyDuty's Avatar
its usually 100+ outside temp if im not mistaken, if your lower ur good
Old Jul 3, 2009 | 04:01 PM
dozerboy's Avatar
Over 200* isn't uncommon ideal is 190* just to check the fluid level. Some built trans are often over 200* it can take it. IIRC it will go into limp mode at 240*or maybe thats was coolant and the trans goes to 260*.
Jake9473
Jul 22, 2018 08:19 AM
PA 24valve
Aug 31, 2015 07:39 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
robbyS
Apr 16, 2015 02:22 PM
Pyrohigh
Oct 11, 2014 07:59 AM
