Power loss
Old Jun 29, 2009 | 09:46 PM
Captn_tyler's Avatar
Default Power loss
I got a little issue here, I have the 6 spd in my truck and the only power mod is that dang Adrenaline box with the pulse meter. When I am crusing down the street, with the box set all the way up, if I stomp it, it goes until about 2200 rpm than it seem it loses power, the engine still it reving, but it dont seem to have power. So I parked it and tried reving it up, it will free rev too about 3000 than boucne around. I assume this is the rev limiter here.
What would cause the sudden power loss?
Tyler
Old Jun 29, 2009 | 10:14 PM
Rooster24v's Avatar
you could be starving the Injection pump... are you running an aftermarket lift pump?
Old Jun 29, 2009 | 10:58 PM
yeah first thing I did, Air Dog 150, new filters
Old Jun 29, 2009 | 11:27 PM
Have you scanned for codes?
Old Jun 29, 2009 | 11:35 PM
only the key flip test, gotta stop by a shop with a scanner
Old Jun 30, 2009 | 12:13 AM
Try downloading a new Quadzilla Tune.
Old Jun 30, 2009 | 12:56 AM
01quadcab's Avatar
Whats your fuel pressure at?
Old Jul 3, 2009 | 11:00 PM
Well mes think its my clutch. Today I was driving around and the truck was grinding into third and a little in too forth. I really had to stomp the pedel down to get it not to grind. fifth and sixth shift fine.
Old Jul 4, 2009 | 01:12 AM
stumpy's Avatar
im not familiar with the adrenaline so this could be way off but did you check your egts to make sure that they are not getting to hot and defueling if you have it set to
Old Jul 4, 2009 | 01:22 AM
bluedodge450r's Avatar
That sounds pretty typical of a clutch problem. Mine did that with 75 nozzles and Juice W Att. all the way up.
