wat are the temps.
Old Jun 27, 2009 | 09:35 PM
bowtech's Avatar
Default wat are the temps.
for the gauge when the pyro is post turbo?
Old Jun 27, 2009 | 10:05 PM
wildbill's Avatar
Should be around 300-400 at idle and 650-800 cruising speed
Old Jun 27, 2009 | 10:30 PM
bowtech's Avatar
so not above 800? wat about boost? wat should the psi should be when crusin?
Old Jun 27, 2009 | 11:10 PM
97cummins's Avatar
At cruising speed for me,60/70mph.I am usually between 5/10psi.
Old Jun 27, 2009 | 11:52 PM
94cummins12v's Avatar
the probe is after the turbo not before those numbers are to much
Old Jun 27, 2009 | 11:53 PM
bowtech's Avatar
wat are they then?
Old Jun 27, 2009 | 11:59 PM
sidekick's Avatar
im running around 900-1000 deg. pre turbo at crusing speeds 60-65 mph
Old Jun 28, 2009 | 12:31 AM
bowtech's Avatar
is after the turbo accurate? even if you make more boost by blockin the waste gate?
Old Jun 28, 2009 | 12:04 PM
i prefer to know wht mu #'s are gong into the turbo becasue there closer to the pistons. aluminum melts about 1200-1300* and that is what your pistons are made of. at idle im at 300-400 and cruising empty 800-900, going up a pass with 6k on the back going 70 im about 1150* pre turbo is way more accurate but its alot harder to mount the probe, just figure what every yours says you are reall 400* more than what it is telling you
Old Jun 28, 2009 | 01:03 PM
bowtech's Avatar
ok thanks brandon. yeah thats where he put it i would of put it in the manifold
