a/c only on the floor
Old Jun 26, 2009 | 08:17 AM
c0zgrove's Avatar
Default a/c only on the floor
hey guys does anyone know why my a/c would only blow on the floor i live in houston and it is ridiculously hot right now and the floor vents aren't cuttin it ive already checked the vaccuum lines under the hood what else could it be
Old Jun 26, 2009 | 08:41 AM
GRI's Avatar
GRI
let me do some searching as this was a common issue on the 2nd gens. stay tuned
Old Jun 26, 2009 | 09:24 AM
Whit's Avatar
Site Mascot
there is a smll door on the system that when closed diverts the air flow from the floor to the dash..........its vavuum operated and must be stuck open
Old Jun 26, 2009 | 09:33 AM
LOGANSTANFORTH's Avatar
my 95 V10 truck did this, if you cover the floor holes it should force the air through the upper vents, i took off the WYE that directs the air left and right and took 3 or 4 old CLEAN socks and stuffed them inside it tight and taped the end of the WYE and it forced the air through the upper vents......
Old Jun 26, 2009 | 02:59 PM
Begle1's Avatar
That's some fine mechanic work there Logan.
It's the mix door, there's probably one or two vacuum actuators that operate it up or down depending on the switch position. Getting to the actuators is usually harder than cleaning them or replacing them or replacing the vacuum line going to them.
Old Jun 28, 2009 | 04:42 PM
89silverbullet's Avatar
on mine i had a constant defrost going it was my vacuum lines
Old Jun 30, 2009 | 10:44 AM
ldogg's Avatar
i had this same problem, i fixed the vacum leak and it still didn't blow through the vents only defrost. so i removed the actuator under the dash behind the transfer case shifter worked in and out a few times and it worked after that, if it is broken i can get the part number for a new actuator i have it some where because i thought mine was broke but after working in and out a few times it una$$ed itself, hope this helps
Old Jun 30, 2009 | 12:07 PM
REDRIDE13's Avatar
must be a mopar thing. I had a jeep cherokee do the same thing years ago
weatherby
Aug 31, 2015 08:04 PM
Maclain Marsh
Jul 13, 2015 06:23 PM
carid
Diesel Bombers Sponsors
Jun 5, 2015 07:42 AM
CumminsCoalRoller24/7
May 5, 2015 08:55 PM
jrsavoie
Shade Tree , Pro-Mechanics & Fabrication
Nov 25, 2014 09:48 AM
