whistle
Old Jun 25, 2009 | 01:06 AM
97cummins's Avatar
Default whistle
A couple weeks ago i started noticing a whistle in my engine area.But it only happens when i'm getting on the throttle.I've checked the intercooler clamps and their tight.Any other ideas?
Old Jun 25, 2009 | 01:24 AM
01superduty89's Avatar
its your turbo hahahaha . if thats not it then idk
Old Jun 25, 2009 | 01:30 AM
97cummins's Avatar
good idea,i'll check it out tommorrow.
Old Jun 25, 2009 | 02:09 AM
94cummins12v's Avatar
if you just noticed it i doubt its your turbo since you havent done any mods to cause this. you may have a boost leak. check you vacuum hose that comes out of the vacuum pump. when i rebuilt my engine last month i forgot to hook the hose up and when i accelerated it was louder than my big turbo
Old Jun 25, 2009 | 10:26 PM
97cummins's Avatar
Where is the vacuum hose?
Old Jun 26, 2009 | 01:11 AM
its on the driver side of the pump
Old Jun 29, 2009 | 01:48 AM
97cummins's Avatar
I did some checking today and found the clamp for the tube that goes from the air filter housing to the turbo intake to be loose.tightened it and tested the truck.The wistle went away a little more,but i can still hear it a little.I also checked the vaccum hose and it looked good.
Old Jun 29, 2009 | 07:13 AM
smokeindodge_12v's Avatar
make sure there not a CRACK IN YOU BOOTS. my buddy though his turbo was junk just a crack in the intercooler boot.
Old Jun 30, 2009 | 04:19 AM
97cummins's Avatar
thanks
Old Sep 28, 2009 | 12:53 AM
97cummins's Avatar
I was doing some checking around in my engine area a couple weeks ago and i noticed that the rt. side negative battery cable was rubbing against the hose that is connected to the wastegate to my turbo.Could have that battery cable have rubbed a small hole in the waste gate hose and thats where my whistling is coming from?
450r racer
Chevy/GMC Duramax 06-07 LBZ
Aug 5, 2015 11:43 PM
farmboy6.9
Mar 23, 2015 12:58 AM
gmcrewcabdually
6.2L & 6.5L Performance
30
Mar 9, 2015 02:58 PM
