ve manual cutoff
Old Jun 25, 2009 | 12:44 AM
Azrattler's Avatar
Default ve manual cutoff
my 1 gen...alright lets see if i can make this clear...was gonna use it as a theft device..took the spring off so the manual pull cable was easier to pull..well i put it on in the same position and was thinking if i moved it a little to where it would shut off with less pull that would be good...well it wouldnt start then i moved it and it wouldnt shut off with the lever...well i got it to where there is about 3/4 throw and then it shuts down it seemed about the same as before i started..was wondering how critical the position of the shaft on the inside of the pump was incase it wasnt exactly the same..
got the truck a week ago and love it..i have been reading and learning alot from you guys ...i know it doesnt have to deal with the pump but oil pressure gauge hangs around the second line of the 4 that are attached is this ok..just replaced the sending unit cause the light use to come on when i would come to a stop...
any info would be great thanks guys
Old Jun 25, 2009 | 05:58 AM
RSWORDS's Avatar
Apparently its pretty picky! Sounds like your fine know though.
Good looking truck!
oh and
Old Jun 25, 2009 | 10:33 AM
Azrattler's Avatar
thanks much RS i wasnt to sure but it seemed right i mean i dont have a clue how that all works other than cuts the fuel off
Old Jun 25, 2009 | 03:21 PM
Begle1's Avatar
If the fuel shut-off lever isn't returning all the way, I do believe that you may be limiting maximum fueling. If you still have as much boost pressure and EGT temperatures now as you did, then you are probably not limiting maximum fueling.
My pull-cable has full articulation of the lever and isn't too hard to pull at all with the stock spring.
Flatbed2001
Aug 9, 2015 12:27 AM
Bigredpowerstroke
Feb 3, 2015 05:48 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
Dec 30, 2014 09:10 AM
