injector pump and injector nozzles ????????
Old Jun 24, 2009 | 07:52 PM
1999 Sport Cummins's Avatar
Default injector pump and injector nozzles ????????
i have a ? bout injector nozzles??? what is the largest size injectors i can get useing my stock injection pump with out having problems?
Old Jun 24, 2009 | 10:32 PM
redneckcummins85's Avatar
i have stage 2 injectors on my truck, and dont have any problems, but i did install a bd diesel performance lift pump to push more fuel to feed the new injectors.
Old Jun 24, 2009 | 11:53 PM
01quadcab's Avatar
It's not the injection pump it's the lift pump and then the turbo. But I would not go over 100hp injectors on the stock turbo
Old Jun 25, 2009 | 12:22 AM
Uncle Bubba's Avatar
Just like he previous post said, it's not the IP that is the hold up it's all the supporting parts. Turbo, Air intake, Exhaust, restrictive innercooler, Fuel Supply, etc... What it all amounts to is the more fuel the more heat to contend with so you have to find some way to cool the system down and keep it breathin fresh air.
Old Jun 25, 2009 | 07:46 AM
ok thanks guys... im thinking about going with 100hp nozzles and a bd performance lift pump, i have a byrds diesel performance intake maifold on the way... would that be a good combo or would i need a bigger exaust
Old Jun 25, 2009 | 09:34 AM
01quadcab's Avatar
I would go with a airdog or fass pump they work and have lifetime warranties plus the added filtration.
Old Jun 25, 2009 | 11:11 AM
With 100 horse sticks if your still runnin the straight pipe in your signature the turbo will still get kinda warm in a hurry but as long as your keepin an eye on your pyro it will be do-able.
To get the full benefit of those sticks your also gonna need some kind of fueling box to fool the computer into sending the extra fuel through to the pump. My personal preference is the Edge products but that's purely a personal decision. Just based off feedback on the sites I would avoid Bullydog and Superchips though, they seem to create a lot a problems with these trucks.
My personal preference for a fuel pump is the MITUSA. It's completely mechanical so no electric motor to go bad and it runs off your flywheel so the more RPM's your turnin the more fuel it's pumpin when you need it the most as opposed to having your highest fuel pressure at idle and then going down as you push the pedal harder. Not that the FASS and AirDog won't both do everything you need them to, just another personal preference.
And definitely spend some time researching what brand of sticks you buy. There are good ones and bad ones on the market and sometimes the most commercial ones are not the best. Get some bad ones and you will be rebuilding an engine in a hurry.
Old Jun 25, 2009 | 04:05 PM
ok thanks i was thinkin edge jammer nozzles but what about 75 sticks
