Looking for some advice. Vp or Common-Rail
Old Jun 23, 2009 | 09:38 PM
Cook's Avatar
Default Looking for some advice. Vp or Common-Rail
Just to start, I'm new to the whole common-rail scene. I've built a couple VP trucks in the past and finally decided to step up to a commin-rail. I'm beginning to get bored with my current setup so I've been looking to add a clutch, 90 hp DDP injector nozzles, and a bigger turbo. But, after talking to one the diesel shops in the area, I'm a little worried. From what he told me, the injectors in the common-rail trucks are notorious for going bad after 100k-125k miles and when you start turning them up that I could scar or melt a hole in the pistons. I believe he said that it was usually #5 or #6. Up to now, the truck has performed flawlessly. The truck has about 81k miles on it now. But... I've got this wicked itch for more power. My question is, should I just sell my truck and just buy another VP or P-pump truck to build up or am I just getting worried about nothing? Any advice would be greatly appreciated. My goal is around 500 hp.
Old Jun 23, 2009 | 11:00 PM
ltr450's Avatar
go for it nothing to worry about the only way you will burn a hole in the piston if you add to much timing to it. 500hp is easy to get out of a common rail.
Old Jun 23, 2009 | 11:18 PM
bobcat67's Avatar
New injector tips usually solves alot of the injector related issues, you can upgrade the injector bodies too but they are expensive, and as long as you have an Air Dog or Fass with the filters on em that'll help out a ton, otherwise 500hp could be done on a stock charger on a Common rail, i bet you could even do 600 a couple times, but then is when you'd probably burn up the turbo, mine has hit 1600 a couple times for like 2 seconds, then i let off the go peddle, also another way to lower egt's is a bigger/better turbo setup more air to compensate for more fuel=lower egt's
Old Jun 24, 2009 | 01:24 AM
Cook's Avatar
Great news guys. What a relief. I REALLY like my truck. I'm gonna order the injector nozzles, a 5" exaust, and a heavier clutch to start off then . I think that I'm going to go with an ATS Aurora 4000 turbo with an ATS exaust manifold in a month or so when I get a little more money saved up.
Old Jun 24, 2009 | 05:36 PM
1badcummins's Avatar
sounds like fun i love my cummins
Notso
Ford Powerstroke 08-10 6.4L
Dec 28, 2016 06:20 AM
yzrider250
Diesel Engine Conversions
Aug 10, 2015 11:33 AM
brianj2077
Aug 4, 2015 09:06 PM
Apr 11, 2015 02:47 PM
twm011
Feb 24, 2015 09:11 AM
