Moving Shop - Must Sell Leftover Parts
Old Jun 23, 2009 | 06:22 PM
XLR8R's Avatar
Default Moving Shop - Must Sell Leftover Parts
Most items were used less than 4K miles and are in great - excellent (like new) condition, except as noted. New prices are listed after part description for reference only.
Best offer on any or all items, F.O.B. 75070 TX - insured FedEx Ground shipping available.
Payment accepted on our website or via USPS to P.O. Box 429 Farmersville, TX 75442.
2008 6.7L BlueTec parts:
rigid plastic engine cover
EGR cooler & mounting bracket $1145
EGR crossover tube & V-band clamps $191
EGR cooler valve & motor assembly $470
EGR intake valve $
EGR air intake flapper & motor assembly $
EGR head-cooler & cooler-riser pipe/hose assemblies
Miscellanous EGR brackets & shields
4" 409SS downpipe & NOX filter with flange & hanger $230
4" 409SS catalytic converter with flanges & hanger $3700
4" 409SS DPF with flange & hanger $2010
4" 409SS straight intermediate pipe
OEM muffler with band clamps $240
4" aluminized steel tailpipe
DPF pressure sensor assembly $66
409SS DPF pressure tubes
2 - EGT probes
2005 5.9L parts:
CR camshaft $1425
air filter housing top, housing, transfer hose & silencer tube assembly $87, $112, $219, $75
fan shroud bellows $130
radiator fan shroud $42
upper radiator hose with clamps
2005 plastic valve cover breather cover $82
passenger side battery box (modified for toolbox mounting) $68
set of remote-mount battery cables
OEM clutch master/slave hydraulic assembly 55K miles $199
OEM throwout bearing & clutch fork 55K miles $109, $44
OEM dual-mass flywheel with Luk clutch (slips past stock power)
2 - CR intake horn (OEM) with or w/o tapped ports $158 each
CR cast exhaust manifold $294
heater grid assembly $142
heater grid relays & wiring harness $189
AC serpentine belt
OEM harmonic balancer $363
fuel filter housing assembly $320
4" 409SS catalytic converter with or w/o media $1100
9.5" AAM differential cover with or w/o drain & powdercoating $76
3rd Gen Non-Drivetrain:
2005 Line-X'd tailgate, complete
OEM 17" forged aluminum satin wheels (4) with center caps
Michelin 285-70R17 LTX-AT tires (4): tread 2x .410" 2x .150"
tan driver side A-pillar molding
tan driver side A-pillar molding with single gauge pod
3 - airbox fender extractor
2 - CAC air deflector
L & R front fenderwells
6 - early sway bar end links $86 each
2 - late sway bar end links $93 each
set of upper & lower control arms $346
new T-case skid plate package $72
OEM heavy-duty rubber overload "springs"
OEM hitch receiver
2 - Predator 17" x 8" aluminum wheels with extra center caps $138 each
3rd Gen High Performance/Accessories
DTT 3-port stainless steel intake horn $290
AirDog 1/2" draw straw $75
5" SS MagnaFlow Pro Series full exhaust with custom tail pipe to clear sway bar $780
SuperLift TorqueMax Select Series traction bars with cross member $650
3/4" x 17" U-bolts with hardware for 10.5" AAM (4) $185
DeeZee black powder coat step bars - Quad Cab $225
Frontier black diamond-plate rear bumper (needs straightening) $225
Top Gun Premium winch-ready black bumper with 2" receiver tube + Hella 65W driving lights, OEM tow hooks & red Xtenders $1200
Ramsey 15K# Patriot electric winch, red roller fairlead + wireless & cabled remote $1500
polished 304SS Tech Tubes - Quad Cab wheel to wheel, complete kit $862
2nd Gen
24V intake horn (OEM)
409SS V10 OEM muffler
V10 OEM cast exhaust manifolds
V10 intake & exhaust rocker arms
V10 coil springs
2 - sway bar end links
Tory4
For Sale
Feb 1, 2015 08:33 PM
