6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
electronic injection to manual injection?
Old Jun 22, 2009 | 10:11 PM
AdamWBennett's Avatar
Star electronic injection to manual injection?
I have a 1993 k2500 with a manual injection pump. The engine has been giving me TONS of fits lately. I have found one from Michigan but its the electronic injection pump. Can I just put the older style pump etc on this engine? I dont want the elctronic injection style and I dont want to have to change the computer and harness etc. Any guidance would be helpful. Also this is a Jasper engine is there anything different about these from the original 6.5s in 93? The new engine only has 19k on it and he says he paid over 7k for it. Same as before any guidance would be great. And if anyone else has a 6.5 preferably the manual injection style with low miles please let me know. I have a 1988 Camaro I am trying to trade off for a 6.5. I have pics its really nice for the age.
Old Jun 22, 2009 | 10:17 PM
Woody35's Avatar
a eletronic pump is not going to work on a oringinally mechanical injected engine without the computer and wiring harness...ETC. your really only option is to get a new IP. Cheap Mechanical 6.5 Injection Pump
by the way what are your problems it might not be your IP
Old Jun 22, 2009 | 10:43 PM
I DONT want the electronic injection. I want to use the MANUAL injection on the electronic engine. The truck body is non-electronic so I dont want to change the wiring harness and computer. The Jasper engine is coming out of a 1998 H1 so I assume its electronic injection. Seems like it should be easy since Im downgrading to less computer stuff.
Old Jun 23, 2009 | 10:29 AM
Woody35's Avatar
oh i get it yeah all you need to do is swap over the parts to the jasper engine. it will fit. though i would keep the GM-8 turbo that is on the 98 and put a turbomaster from heath to keep it mechanical because it is a better turbo than the turbo you have on the 93 right now
Old Jun 23, 2009 | 06:40 PM
Right on! Thanks!
Oh and I already have a turbomaster I built from stuff at the hardware store. I havent even gotten to try it out yet the truck has been broke since I got around to making it.
Last edited by AdamWBennett; Jun 23, 2009 at 06:40 PM. Reason: Automerged Doublepost
Old Jun 23, 2009 | 07:47 PM
Woody35's Avatar
well thats fine just switch the turbomaster from the GM-3 turbo that is on the 93 to the GM-8 that is on 98 and put the GM-8 on your jasper engine because the newer turbo spools faster and flows more air.
also i would put the 98 air intake on the engine instead of the orginial air intake beacuse that also flows more air. then after switching all the newer parts on just connect up the fuel system and all the other stuff and you should be good. it should feel faster with the new turbo and intake
Old Jun 23, 2009 | 09:06 PM
Thanks for all the help! Are the Jasper blocks any different from the original 93s? I have seen places advertising an "improved 6.5 block" was just curious if this would fall into that improved block category. Was that standard for the later model blocks or just aftermarket?
Old Jun 23, 2009 | 09:16 PM
Woody35's Avatar
the GEP Optomizer block is improved block but those are big bucks $$$. but beware there are a lot of Chinese knockoffs that are avertised as improved but really are not and in most cases fail easier.
i dont know specifics but i would assume the jasper engine is the same. actually the 97 through 2000 6.5 blocks from GM had oil cooler jets that injected oil at the piston. these blocks tend to crack a lot easier so you would hope jasper used the older desighn block as a replacement. i tried jaspers website and it seemed like you had to sighn up to see engine details so you could try there for more info.
Bigredpowerstroke
Feb 3, 2015 05:48 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
Dec 30, 2014 09:10 AM
