injector leakin on my 12 valve
Old Jun 22, 2009 | 10:17 AM
biged681985's Avatar
Default injector leakin on my 12 valve
i put a 12 valve in the truck a few months ago and it has been leaking since installed. they are the stock injectors. i have went through another thread and i put grease on the injector when i pulled it to try sealing it better, i took sand paper to it, i torqued it to just a lil tighter then the stock specs. it wont leak now at an idle or when it is free reved, but under a load it still leaks quite bit. unless the copper washer s bad on the return bolt it aint leaking fromn the return bolt cause it is tight. any suggestions?
Old Jun 22, 2009 | 10:23 AM
wildbill's Avatar
Copper washer and or the o-ring are bad.
Old Jun 22, 2009 | 08:32 PM
94cummins12v's Avatar
im thinkin its the copper washer becuase that o-ring on the top dont seal diesel they only seal dirt from getting inthere
Old Jun 24, 2009 | 08:05 AM
daveO's Avatar
Make sure you clean out the injector bores real good before you put the injectors in. It's easy to get soot and carbon buildup on the seating surface when you're changing them out. I use a cleaning brush for a shotgun to clean the bores. If you get stuff in there, the copper washers will never seal.
Old Jun 24, 2009 | 10:25 AM
yep thats a good point. also i found out that if there is enough stuff in there they wont only seal but it will raise the injector .020-.010 away from the piston causing it make the injector nozzel not fire into the piston bowl
Old Jun 24, 2009 | 03:31 PM
daveO's Avatar
That makes sense. I never even thought of that aspect.
Old Jun 25, 2009 | 02:07 AM
i noticed that when i yanked my head last week. you can see the injector pattern on the head and not the piston
Old Jun 25, 2009 | 08:00 AM
wtfd6's Avatar
Bombardier
It is probably a body leak on the injector. the injectors need to be repaired.
Old Jun 25, 2009 | 11:12 AM
xzaq103's Avatar
FormerVendor
SOunds like its time for some new sticks ED. I got an idea for ya anyway we can talk about it at Seneca this weekend
RA113024
Mar 13, 2016 07:42 PM
jeremiah1
Jul 21, 2015 06:35 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
behrendt1061
Dec 4, 2014 05:49 PM
