Loosin my mind!!
Old Jun 21, 2009 | 09:56 PM
Stacked03's Avatar
Default Loosin my mind!!
Was kickin and sputterin Ok thought that pulling the banks 6-gun had worked. WRONG!!! Helped with the sputterin a bit. Replaced the Crank sensor, that helped a little. Now it idols somewhat correctly and has no power at all! Could barely hold 50mph. I can lay into it and get nothing but the sound of a ticked off lawnmower. Codes its popping are as such... P0336 Crank shaft position (CKP) Sensor signal, P2149 Bank 2 (Cylinders 4-6) Shorted high or low, P0647 High Voltage detected at the A/C clutch relay. I have until Thursday to get it fixed to milk it from Maryland to Ohio so I can get it into the shop. I get layed off Thursday and home is Ohio. PLEASE anyone with a suggestion of a fix PLEASE let me know what you think! Shutting it off clearing the codes and starting it up helps a little, but the problem comes back soon there after!
Old Jun 21, 2009 | 10:05 PM
wildbill's Avatar
What codes pop back up after clearing them??
Old Jun 21, 2009 | 10:43 PM
sidekick's Avatar
try to erase the memory with power loss battery unhook 5 mins.
Old Jun 22, 2009 | 05:47 AM
Stacked03's Avatar
P0336 Crank shaft position (CKP) Sensor signal, P2149 Bank 2 (Cylinders 4-6) Shorted high or low, P0647 High Voltage detected at the A/C clutch relaycome back, Ive tried the battery reset twice now!
Old Jun 22, 2009 | 07:18 AM
wildbill's Avatar
Double check all the connections and make sure non of the pins are bent/broke.
cummins Pride
Sep 9, 2015 10:55 AM
